Rapid Storage Technology
Intel® RST, RAID
2178 Discussions
No Rebuild option in RST - RAID 5 reads as RAID 0 and won't auto rebuild to spare
evo
I have a 4 disk RAID 5, and recently, it appears one drive dropped out of the RAID.
I installed a new drive, and it's recognized, but I cannot do anything with it.
RST does not give me any option to rebuild, or repair. I was able to set the new drive 'Mark as spare' but it does nothing else, no auto rebuild, or option for manual rebuild.
I do not have a backup, as I was just about to start one on a new ext hd I bought (funds also would not allow for the longest time)
I specifically set this up as RAID 5 as it offers a great mix of capacity and security, but what's the point if I can't do anything, as is the case now? It may have well been a Striped array.
Although now i'm not even sure it was a RAID 5 tbh...iirc I had about 16TB capacity, on 4 x 5TB drives, so a RAID 0 would seem more likely...
Either way, any one have any ideas as to what is going on? if it were in fact a RAID 5, I should be able to rebuild, no?
If it was actually a RAID 0, am I completely SOL?
here's the system report (attached):
David_G_Intel
Hello evo
Thank you for posting on the Intel️® communities.
On the report provided we noticed that this was a RAID 0 instead of a RAID 5:
You can't recover or repair that RAID 0 because of the failed drive but you can create a new RAID 0 (or other) following the steps below:
  1. Turn off the computer.
  2. Replace the failed hard drive with a new hard drive of equal or greater capacity.
  3. Turn on the computer. When prompted during system startup, press Ctrl+I at the same time to enter the option ROM user interface.
  4. Click 2. Delete RAID Volume.
  5. Use the up or down arrow keys to select the failed RAID 0 volume.
  6. Press Delete to delete the volume.
  7. Press Y to confirm the deletion.
  8. Click 1. Create RAID Volume and follow the prompts to create a RAID 0 volume.
  9. Click 6. Exit.
David G
Intel Customer Support Technician
David_G_Intel
David G.
evo
yeah, thanks. i know how to set up a new RAID, but I cannot get into ' option ROM user interface'. doesn't matter though.
looks like i'll just haev to wipe and start over... turns out i forgot i had switched from RAID 5 to RAID 0 when i needed more space and couldn't afford more drives. I knew the risk, and here we are
thanks
David_G_Intel
We're glad to know the information helped. Hopefully, it will help other community members. Since the thread is now solved, we will proceed to close it.
David G
