Rapid Storage Technology
Intel® RST, RAID
2189 Discussions
SSD doesn't show in Storage System View
JRior
I just installed a Samsung NVMe SSD 960 Pro in my desktop, as a boot drive. It's fully operational but it's not showing up on the Storage System View in the Intel RST application. Is this a problem or is it simply because it's not a SATA device?
n_scott_pearson
I believe that NVMe drives can be supported by RST, but only if the BIOS contains support for redirection and it is enabled in the BIOS configuration.
JRior
RST does support NVMe. But my understanding is that I can't combine NVMe and SATA storage in the same RAID configuration using RST. I've opted for a SATA configuration in my BIOS. I'm trying to find out if the NVMe isn't showing in the Intel application due to a glitch of some kind, or it's not showing simply because I can't use it? Thanks!
Hello adelpit,
It would be great to have additional information about the Intel Rapid Storage Technology you are using. Please follow the steps below:
View System Report
To view a system report, follow these steps:
  1. Open the Intel Rapid Storage Technology user interface (Start > Programs > Intel > Intel® Rapid Storage Technology).
  2. Click the Help icon.
  3. Click the System Report icon.
Save System Report
To save a system report, follow these steps:
  4. Click Save.
I look forward to hearing from you.
Wanner G.
Hello adelpit,
I am just following up on your inquiry. I will be glad to assist you if you need any further help.
Wanner G.
JRior
Wanner,
I hope this post gets your attention. It appears that, in my delay, the thread has been closed. I still can't see my NVMe SSD in the Intel RST app. I tried installing the Samsung Magician app. It tells me everything's OK with the drive, but it didn't show up in the Intel app. As requested, here's a copy of my System Report:
System Report
System Information
OS name: Microsoft Windows 10 Home
OS version: 10.0.16299
System name: DESKTOP-42U1M0K
System manufacturer: Dell Inc.
System model: XPS 8900
Processor: GenuineIntel Intel64 Family 6 Model 94 Stepping 3 3.408 GHz
BIOS: Dell Inc., 2.2.1
PCH: 0xA145
Intel® Rapid Storage Technology enterprise Information
Kit installed: 15.7.5.1025
User interface version: 15.7.5.1025
Language: English (United States)
RAID option ROM version: 14.0.0.2209
Driver version: 15.7.5.1025
ISDI version: 15.7.5.1025
Storage System Information
RAID Configuration
Hardware Information
Controller name: Intel(R) Chipset SATA/PCIe RST Premium Controller
Type: SATA
Mode: RAID
Number of SATA ports: 5
Number of volumes: 0
Number of spares: 0
Number of available disks: 1
Rebuild on Hot Plug: Disabled
Manufacturer: Intel Corporation
Model number: 0x2822
Product revision: 49
Direct attached disk: Z4YBLZ4Y
Disk on Controller 0, Port 0
Status: Normal
Type: SATA disk
Location type: Internal
Usage: Available
System disk: No
Disk data cache: Enabled
Command queuing: NCQ
Transfer rate: 6 Gb/s
Model: ST1000DM003-1ER162
Serial number: Z4YBLZ4Y
SCSI device ID: 0
Firmware: CC45
Physical sector size: 40...
Hello adelpit,
You have an old Intel® Rapid Storage Technology driver version installed: Version: 15.7.5.1025 ,A03.
Try installing a newer generic version and check if your NVMe SSD 960 Pro shows up on the Storage System View.
Version: https://downloadcenter.intel.com/download/27400/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver?product=55005 15.9.0.1015 (Latest)
Wanner G.
Hello adelpit,
Were you able to install the Intel® Rapid Storage Technology driver provided before? Please let me know if you need any further help.
Wanner G.
JRior
Wanner,
I'm afraid that didn't work. I installed the latest app and driver. The SSD still doesn't show, even after scanning for hardware within the Intel app. Any suggestions? Thanks.
Kit installed: 15.9.0.1015
User interface version: 15.9.0.1015
Driver version: 15.9.0.1015
ISDI version: 15.9.0.1015
Hello adelpit
Thank you for your response.
Do you know if on your system the NVMe SSD is been handled by a different SATA controller?
Leonardo C.
n_scott_pearson
I have two thoughts:
  1. I wonder if the Redirection feature is not being enabled in BIOS (if indeed the BIOS provides support for this capability)?
  2. I wonder if this is as a result of the Samsung NVMe driver being loaded?
