Rapid Storage Technology
Intel® RST, RAID
2188 Discussions
high CPU usage of Intel(R) Rapid Storage Technology Management Service
veer
12 265 Visites
My laptop is doing nothing and suddenly out of nowhere fan ramp up like I am playing some game. Upon checking into task manager it was intel rapid storage technology, taking almost 100% of SSD usage and 40% of CPU usage. This high CPU usage thing is happening since I bought the laptop(15 months ago). I thought it was normal. Is this normal behavior or I am having some real issues?
0 Compliments
17 Réponses
DeividA_Intel
Employé
12 250 Visites
Hello veer,
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
· Download the Intel® SSU and save the application on your computer: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
· Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
· To save your scan, click Next and click Save.
2. If possible, provide a report from the Intel® Rapid Storage Technology.
- https://www.intel.com/content/www/us/en/support/articles/000006351/technologies.html
3. Do you use the Intel® Rapid Storage Technology? If so, what is your RAID configuration?
4. Are you using the latest Intel® Rapid Storage Technology driver version from your laptop manufacturer?
5. Can you take pictures from the task manager?
Deivid A.
0 Compliments
veer
12 242 Visites
scan of Intel® System Support Utility (Intel® SSU)
0 Compliments
DeividA_Intel
Employé
12 233 Visites
Hello veer,
Thanks for the report.
In order to continue, I would appreciate it if you can help me with the following questions:
1. Have you updated the BIOS?
2. Do you use the Intel® Rapid Storage Technology? If so, what is your RAID configuration?
3. Are you using the latest Intel® Rapid Storage Technology driver version from your laptop manufacturer?
4. Can you take pictures from the task manager?
Deivid A.
0 Compliments
veer
12 206 Visites
yes I have updated my bios. I have everything I could find.
And the rest I have given in ss.
0 Compliments
veer
12 206 Visites
This rapid storage thing is again running after a week (today). it is running continuously for more than 2 hour
0 Compliments
veer
12 202 Visites
still consuming CPU non stop
0 Compliments
DeividA_Intel
Employé
12 198 Visites
Hello veer,
Deivid A.
0 Compliments
DeividA_Intel
Employé
12 184 Visites
Hello veer,
I would like to confirm some information:
1. Are you using this for Raid or any volume?
If you are not using the Intel® Rapid Storage Technology (Intel® RST) to crate a RAID or a volume, you can proceed to uninstall it since in not being used.
Follow the steps from this manual:
- https://www.intel.com/content/dam/support/us/en/documents/technologies/intel-rst-installation-and-user-guide.pdf
Deivid A.
0 Compliments
veer
12 174 Visites
A. Is it not specified in the screenshot provided? I have given a ss of disk management.
If i am not using it, why is it taking so much cpu. If intel optane memory is provided in my laptop, i want to use it. Tell me how to use not uninstalling.
Is there any way to chat live, this community thing takes a lot time to solve problem
0 Compliments
veer
12 174 Visites
If I am not using it, why is it taking so much CPU. If intel Optane memory is provided in my laptop, I want to use it. Tell me how to use not uninstalling.
Is there any way to chat live, this community thing takes a lot time to solve problem.
0 Compliments
veer
12 174 Visites
As far as I know both Optane and SSD are in same drive, is there any way to separate it and use it.
0 Compliments
DeividA_Intel
Employé
12 138 Visites
Hello veer,
Thanks for the information provided.
In order to proceed, please help me with the following information:
1. Are you using the Intel® Rapid Storage Technology (Intel® RST) version from Asus or Intel?
2. What is the Intel® Rapid Storage Technology (Intel® RST) driver version?
3. What is your RAID configuration? Or, are you using the Intel® Rapid Storage Technology (Intel® RST) just to control the Optane memory?
I would like to let you know that we provide support for Intel® Rapid Storage Technology (Intel® RST) via web ticket (email), not on live support.
You will find information about how to control the Optane memory in the following links. However, since it is installed on a laptop some features/options may be limited by the manufacturer (Asus) and I recommend you to get in contact with them for specific instructions like if is possible to use the SSD and Optane memory individually even if are the same drive.
- https://www.intel.com/content/www/us/en/support/articles/000024018/memory-and-storage/intel-optane-memory.html
- https://www.intel.com/content/www/us/en/support/articles/000057208/technologies/intel-rapid-storage-technology-intel-rst.html
Deivid A.
0 Compliments
veer
12 115 Visites
this error message is appearing
0 Compliments
veer
12 113 Visites
yesterday I installed Optane memory app on my device to check the details you asked for. after that I pinned some apps to it. then a restart and windows went blue screen error saying, unmount able drive. I made windows reset. (before resetting) I have disabled all my notification(may be that was reason I didn't received this notification before). after reset the notification started popping up whenever I open explorer.
0 Compliments
DeividA_Intel
Employé
12 094 Visites
Hello veer,
Thanks for the information.
In this case, I will appreciate it if you can provide the following details:
1. Did you receive the same error with Windows 10?
2. Can you re-install Windows 10 and provide the information previously requested?
Deivid A.
0 Compliments
DeividA_Intel
Employé
12 069 Visites
Hello veer,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
0 Compliments
DeividA_Intel
Employé
12 054 Visites
Hello veer,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
0 Compliments
Répondre
