Hello forum users! need your help! the fact is that in my driver support assistant application always displays an update for intel® rapid storage technology (intel® rst), although this driver is installed and updated, I have already uninstalled and installed again that the program itself is for updates, that driver, but it does not help, can anyone know how to fix it? very annoying, constantly comes out a message about the update! Thank you!
Здравствуйте пользователи форума! Нужна ваша помощь! Дело в том , что у меня в приложении Driver Support Assistant всегда отображается обновление для Технологии хранения Intel® Rapid (Intel® RST) , хотя этот драйвер установлен и обновлен, я уже и удалял и снова устанавливал, что саму программу для обновлений, что драйвер, но это не помогает,может кто знает как это исправить? Очень надоедает,постоянно вылазит сообщение о обновлении! Спасибо!
Tell it to hide this update.
Hello Alexks
Thank you for posting on the Intel️® communities. Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
We understand that the Intel® DSA suggests an Intel® RST update even when the drivers are up to date, is this correct? If it is please let us know the latest RST driver you installed and share with us the Intel® System Support Utility (Intel® SSU) results
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
David G
David G.
David G.
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
