Just to make sure you understand the potential impact here: When the drive fails completely, you lose everything that is stored on it. At a minimum, you should make a full backup of its contents. But, do not consider this as a solution; you are going to have to replace the drive regardless; it is simply a matter of time before its complete failure forces you to do so.
You've been warned,
Thank you. So isn't there a solution to fix this?
Yes, replacing the drive will fix this.
You've been warned,
![](/skins/images/BC9A7A3465121B56B278007F4EE8899F/responsive_peak/images/icon_anonymous_message.png)
