Rapid Storage Technology
Intel® RST, RAID
2189 讨论
sata disk on controller 0 port 0 at risk (smart event)
Nazdi
初学者
1,524 次查看
I get this error message every time I restart or on my laptop. Is there anything I can do to fix this problem?
Thank you.
0 项奖励
1 解答
n_scott_pearson
超级用户
1,491 次查看
Just to make sure you understand the potential impact here: When the drive fails completely, you lose everything that is stored on it. At a minimum, you should make a full backup of its contents. But, do not consider this as a solution; you are going to have to replace the drive regardless; it is simply a matter of time before its complete failure forces you to do so.
You've been warned,
在原帖中查看解决方案
0 项奖励
4 回复数
n_scott_pearson
超级用户
1,515 次查看
The S.M.A.R.T. subsystem is telling you that this drive is predicting its own imminent failure. You should obtain a replacement and transfer your data from this drive before it fails completely.
0 项奖励
Nazdi
初学者
1,506 次查看
Thank you. So isn't there a solution to fix this?
0 项奖励
AlHill
超级用户
1,498 次查看
Yes, replacing the drive will fix this.
n_scott_pearson
超级用户
1,492 次查看
You've been warned,
0 项奖励
回复
