Rapid Storage Technology
Intel® RST, RAID
2189 Discussions
which version should I have?
pls2000
I'm running Windows 10 Pro x64 on an HP Z230 workstation. Part of he IRST report is attached to the bottom of this message.
The System Report says I am running IRST kit 15.8.1.1007. What I have is working fine, but I need to get the Windows F6 disk that matches the driver version I'm running This version is no longer available for download although a version 15.9 is.
Should I update to the 15.9 drivers? A different version?
And where do I find the download for the F6 disk?
System Report
System Information
OS name: Microsoft Windows 10 Pro
OS version: 10.0.19041
System name: QUARTZ
System manufacturer: Hewlett-Packard
System model: HP Z230 Tower Workstation
Processor: GenuineIntel Intel64 Family 6 Model 60 Stepping 3 3.401 GHz
BIOS: Hewlett-Packard, L51 v01.55
PCH: 0x8C56
Intel® Rapid Storage Technology enterprise Information
Kit installed: 15.8.1.1007
User interface version: 15.8.1.1007
Language: English (United States)
RAID option ROM version: 12.7.0.1936
Driver version: 15.8.1.1007
ISDI version: 15.8.1.1007
Storage System Information
RAID Configuration
Array Name: SATA_Array_0001
Available space: 2 MB
Number of volumes: 2
Volume member: Data_Volume
Volume member: Cache_Volume
Number of array disks: 1
Array disk: S1G1NYAFA01187
Disk data cache: Enabled
Volume name: Data_Volume
Status: Normal
Type: RAID 0
Usage: Data volume
System volume: No
Data stripe size: 128 KB
Write-back cache: Off
Initialized: Yes
Parity errors: 0
Blocks with media errors: 0
Physical sector size: 512 Bytes
Logical sector size: 512 Bytes
Volume name: Cache_Volume
Status: Normal
Type: RAID 0
Usage: Cache volume
System volume: No
Initialized: Yes
Parity errors: 0
Hardware Information
Controller name: Intel(R) Chipset SATA/PCIe RST Premium Controller
Type: SATA
Mode: RAID
Number of SATA ports: 3
Volume: Data_Volume
Volume: Cache_Volume
Number of spares: 0
Number of available disks: 1
Rebuild on Hot Plug: Disabled
Manufacturer: Intel Corporation
Model number: 0x2822
Product revision: 5
Direct attached disk: MK0371YHK0Z1RG
Direct attached disk: S1G1NYAFA01187
Disk on Controller 0, Port 0
Status: Normal
Type: SATA disk
Location type: Internal
Usage: Accelerated disk
Acceleration mode: Maximized
System disk: Yes
Command queuing: NCQ
Transfer rate: 6 Gb/s
Model: Hitachi HDS723030ALA640
Serial number: MK0371YHK0Z1RG
SCSI device ID: 0
Firmware: MKAOAA10
Disk on Controller 0, Port 1
Status: Normal
Type: SATA SSD
Usage: Cache device
System disk: No
Model: SAMSUNG MZ7WD480HCGM-00003
Serial number: S1G1NYAFA01187
SCSI device ID: 0
Firmware: DXM91M3Q
ATAPI device on Controller 0, Port 5
Transfer rate: 1.5 Gb/s
Model: hp DVD-RAM UJ8E1
Serial number: Not Available
Firmware: 4H01
AndrewG_Intel
Hello pls2000
This feature seems to be soported for installation on Legacy versions of Windows.
Please allow us to take a look into this inquiry and we will be posting back in the thread as soon as we have more information available.
Andrew G.
AndrewG_Intel
Hello pls2000
After checking this further, we would like to inform you that when running Intel® Optane™ Memory and Storage Management application or Intel® Rapid Storage Technology (Intel® RST) on a system with a Server-based Chipset like the HP Z230 workstation (Intel C226 chipset), the support for these scenarios and for Server-Chipset systems should be through the original computer manufacturer (OEM). In this case, our recommendation is to address this inquiry to your OEM HP* which is the proper channel of support. Thank you for your understanding.
Here is the HP* support link: https://support.hp.com/us-en
Andrew G.
*Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel® or any of its products is implied.
pls2000
That's interesting, because it was this forum that told me to run the version I now have.
Can you at least tell me where to get the Windows F6 disk for IRST 15.8?
n_scott_pearson
Closest I could find is 15.9.8.1050, which you can download from here: https://downloadcenter.intel.com/download/28997/Intel-Rapid-Storage-Technology-Intel-RST-User-Interface-and-Driver?product=55005. This should be close enough that you can load the drivers and still use the runtime. If not, the files for upgrading RST to 15.9 are there as well.
Hope this helps,
AndrewG_Intel
Hello pls2000
Thank you for your response.
The information provided by n_scott_pearson is correct meaning that we offer Intel® Rapid Storage Technology (Intel® RST) version 15.9.8.1050. The other version you are looking for (15.8) is not even on our Download Center.
If more assistance is required, our recommendation is to check this further with your OEM due to the reason previously provided: System with a Server Chipset. For this scenario, your OEM is the proper channel of support.
We will proceed to close this thread now from our end; however, communications with community peers can continue in case they have additional suggestions. If you need any other information, please submit a new question as this thread will no longer being monitored.
Andrew G.
