Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4883 Discussions
Add additional Fans to P4000XXSFDR
JThom14
Simple question!
With the system set to performance (S1200SPL board), the fans are quite loud.
Does anyone know if I can add additional fans to the P4000XXSFDR chassis? The MoBo supports additional fans and I would like the system to stay cooler and not spin up the fans so often.
thanks,
-Joe
JThom14
Hi Caesar-
I didn't see your last post until just now. Yesterday I visited the office and did swap the power supplies. What should we look for now, or should I re-send the logs after X days? Assuming I don't need to RMA.
-Joe
Hello jetcosys ,
In order to expedite the resolution of this case please http://www.intel.com/content/www/us/en/support/contact-support.html Contact Support
Caesar B
JThom14
Caesar-
I spoke with support today and they want me to now update to the latest firmware - not sure why this wasn't requested before. I'll get that done asap. Once done, which logs do you need to see to validate the fan issue has stopped?
-Joe
Hello Joe,
We are wondering if you were able to get the requested logs and if further assistance is required.
Caesar B.
Hello Joe,
We are wondering if further assistance is still required in this case. If you were able to solve the issue, please feel free to share the solution in this thread so others could take advantage of your findings.
Caesar B.
JThom14
Hello Caesar-
Apologies for the delay, I had to wait for the office to have a downtime to update the firmware. Firmware installation is complete. Here is the latest syslog:
System Information Retrieval Utility Version 14.0 Build 12
Copyright (c) 2015 Intel Corporation
Platform Firmware Inventory
BIOS Version....... S1200SP.86B.02.01.0055
BMC Firmware Version:
Op Code....... 0.20.9366
Boot Code.............. 01.05
ME Firmware Version:
Boot Code: 04.01.03.021
SDR Version:
SDR version: SDR Package 0.22
Sensors
LUN NAME NUMBER OWNER UNITS VALUE
0 BMC Watchdog 10 32 STATE_DEASSERTED
0 VR Watchdog 11 32 STATE_DEASSERTED
0 SSB Therm Trip 13 32 STATE_DEASSERTED
0 IO Mod Presence 14 32 DEVICE_REMOVED/DEVICE_ABSENT
0 SAS Mod Presence 15 32 DEVICE_REMOVED/DEVICE_ABSENT
0 BMC FW Health 16 32 OK
0 System Airflow 17 32 CFM 20.000000
0 BB P1 VR Temp 32 32 Degrees Celsius -73.000000
0 P1 VR Ctrl Temp 186 32 Degrees Celsius 32.000000
0 Front Panel Temp 33 32 Degrees Celsius 28.000000
0 Pwr Unit Status 1 32 ALL_DEASSERTED
0 SSB Temp 34 32 Degrees Celsius 36.000000
0 BB Inlet Temp 35 32 Degrees Celsius 26.000000
0 BB BMC Temp 36 32 Degrees Celsius 32.000000
0 BB Mem VR temp 37 32 Degrees Celsius -72.000000
0 Exit Air Temp 46 32 Degrees Celsius 31.000000
0 System Fan 1 52 32 RPM 2250.000000
0 System Fan 4 51 32 RPM 816.000000
0 Processor 1 Fan 48 32 RPM 1008.000000
0 PS1 Status 80 32 PRESENCE_DETECTED
0 PS2 Status 81 32 PRESENCE_DETECTED
0 Pwr Unit Redund 2 32 FULLY_REDUNDANT
0 PS1 Input Power 84 32 Watts 60.000000
0 PS2 Input Power 85 32 Watts 4.000000
0 PS1 Curr Out % 88 32 % 10.000000
0 PS2 Curr Out % 89 32 % 0.000000
0 PS1 Temperature 92 32 Degrees Celsius 30.000000
0 PS2 Temperature 93 32 Degrees Celsius 41.000000
0 PS1 Fan Fail 160 32 STATE_DEASSERTED
0 PS2 Fan Fail 164 32 STATE_DEASSERTED
0 P1 Status 112 32 PROCESSOR_PRESENCE_DETECTED
0 P1 Therm Margin 116 32 Degrees Celsius -71.000000
0 IPMI Watchdog 3 32 OK
0 P1 Therm Ctrl % 120 32 % 0.000000
0 CPU Missing 130 32 STATE_DEASSERTED
0 P1 DTS Therm Mgn 131 32 Degrees Celsius -51.000000
0 CATERR 128 32 STATE_DEASSERTED
0 VRD Hot 144 32 Degrees Celsius LIMIT_NOT_EXCEEDED
0 DIMM Thrm Mrgn 1 176 32 Degrees Celsius -128.000000
0 Mem P1 Thrm Trip 192 32 OK
0 Agg Therm Mgn 1 200 32 Degrees Celsius -7.000000
0 BB +12.0V 208 32 Volts 11.936000
0 BB +3.3V Vbat 222 32 Volts 3.088800
0 Physical Scrty 4 32 OK
0 Voltage Fault 209 32 STATE_DEASSERTED
96 NM Capabilities 26 44 POLICY_INTERFACE_AVAILABLE, MONITORING_AVAILABLE, POWER_LIMITING_AVAILABLE
96 MTT CPU1 52 44 % 0.000000
0 FP NMI Diag Int 5 32 OK
0 SMI Timeout 6 32 STATE_DEASSERTED
0 System Event Log 7 32 OK
0 System Event 8 32 OK
0 Button 9 32 OK
Sensor Data Records
Total Number of SDR Records: 195
Displaying SDR Record id: 1
01 00 51 02 2a 20 00 01 15 01 67 40 09 6f 75 00 ..Q.*.....g@.ou.
75 00 75 00 c0 00 00 01 00 00 00 00 00 00 00 cf u.u.............
50 77 72 20 55 6e 69 74 20 53 74 61 74 75 73 Pwr.Unit.Status
Displaying SDR Record id: 2
02 00 51 02 2a 20 00 02 15 01 67 00 09 0b ff 00 ..Q.*.....g.....
ff 00 ff 00 00 00 00 01 00 00 00 00 00 00 00 cf ................
50 77 72 20 55 6e 69 74 20 52 65 64 75 6e 64 Pwr.Unit.Redund
Displaying SDR Record id: 3
03 00 51 02 28 20 00 03 07 01 67 40 23 6f 0f 01 ..Q.(.....g@# o..
00 00 0f 01 c0 00 00 01 00 00 00 00 00 00 00 cd ................
49 50 4d 49 20 57 61 74 63 68 64 6f 67 IPMI.Watchdog
Displaying SDR Record id: 4
04 00 51 02 29 20 00 04 17 01 67 40 05 6f 11 00 ..Q.).....g@.o..
11 00 11 00 c0 00 00 01 00 00 00 00 00 00 00 ce ................
50 68 79 73 69 63 61 6c 20 53 63 72 74 79 Physical.Scrty
Displaying SDR Record id: 5
05 00 51 02 2a 20 00 05 0c 01 67 40 13 6f 01 00 ..Q.*.....g@.o..
00 00 01 00 c0 00 00 01 00 00 00 00 00 00 00 cf ................
46 50 20 4e 4d 49 20 44 69 61 67 20 49 6e 74 FP.NMI.Diag.Int
Displaying SDR Record id: 6
06 00 51 02 26 20 00 06 07 01 67 40 f3 03 02 00 ..Q.&.....g@....
02 00 02 00 c0 00 00 01 00 00 00 00 00 00 00 cb ................
53 4d 49 20 54 69 6d 65 6f 75 74 SMI.Timeout
Displaying SDR Record id: 7
07 00 51 02 2b 20 00 07 07 01 67 40 10 6f 04 00 ..Q.+.....g@.o..
00 00 04 00 c0 00 00 01 00 00 00 00 00 00 00 d0 ................
53 79 73 74 65 6d 20 45 76 65 6e 74 20 4c 6f 67 System.Event.Log
Displaying SDR Record id: 8
08 00 51 02 27 20 00 08 07 01 67 40 12 6f 10 00 ..Q.'.....g@.o..
00 00 10 00 c0 00 00 01 00 00 00 00 00 00 00 cc ................
53 79 73 74 65 6d 20 45 76 65 6e 74 System.Event
Displaying SDR Record id: 9
09 00 51 02 21 20 00 09 0c 01 67 40 14 6f 05 00 ..Q.!.....g@.o..
00 00 05 00 c0 00 00 01 00 00 00 00 00 00 00 c6 ................
42 75 74 74 6f 6e Button
Displaying SDR Record id: 10
0a 00 51 02 27 20 00 0a 2e 01 67 40 28 03 02 00 ..Q.'.....g@(...
00 00 02 00 c0 00 00 01 00 00 00 00 00 00 00 cc ................
42 4d 43 20 57 61 74 63 68 64 6f 67 BMC.Watchdog
Displaying SDR Record id: 11
0b 00 51 02 26 20 00 0b 07 01 67 00 02 03 02 00 ..Q.&.....g.....
56 52 20 57 61 74 63 68 64 6f 67 VR.Watchdog
<p...
Hello Joe,
Thanks for providing the requested information.
We will proceed to analyse it and reply back with more troubleshooting steps as soon as possible.
Caesar B.
