hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Server Products
5006 Discussions
Cannot install CmdTool2 on Debian
The server hardware: S5500BCR (Bluff Creek) 8DIMM, 2 x Intel Quad-Core Xeon® E5506
Raid controller: Intel SRCSASLS4I, PCI Express x8
I have downloaded http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Server+Products&ProductLine=Intel%C2%AE+RAID+Controllers&ProductProduct=Intel%C2%AE+RAID+Controller+SRCSASLS4I http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Server+Products&ProductLine=Intel%C2%AE+RAID+Controllers&ProductProduct=Intel%C2%AE+RAID+Controller+SRCSASLS4I
and tried to convert rpm to deb with "alien", but "alien -d CmdTool2-5.00.14-1.i386.rpm" fails:
dpkg-shlibdeps: failure: couldn't find library libncurses.so.5 needed by debian/cmdtool2/opt/MegaRAID/CmdTool2/CmdTool2 (its RPATH is '').Note: libraries are not searched in other binary packages that do not have any shlibs or symbols file.To help dpkg-shlibdeps find private libraries, you might need to set LD_LIBRARY_PATH.dh_shlibdeps: command returned error code 512make: [binary-arch] Error 1 (ignored)dh_gencontroldpkg-gencontrol: error: current host architecture 'amd64' does not appear in package's architecture list (i386)dh_gencontrol: command returned error code 65280make: *** [binary-arch] Error 1find: `CmdTool2-5.00.14': No such file or directory
The question: there is a way to monitor SRCSASLS4I controller under debian with 64bit?
thanks
Daniel_O_Intel
Not that I know of. By the messages below, it looks like alien is not going to be able to repackage the RPM.
Ok, understood.
My primary question: is there a way, to monitor the raid controller under Debian? Somebody has experience with that?
The cmdtool2 package for linux supplied by Intel is for i386 builds, not x86_64,
If enough people ask (nicely) they might make a 64bit package available. One can hope anyway.
In the meantime it's possible to install it, but it makes a mess out of your libraries to do so.
CoryJ_K_Intel
Hi because I think you'll get more answers from the main Server Tech Support Forum.
I moved this discussion there.
The link is: /message/115975# 115975 http://communities.intel.com/message/115975# 115975
- Cory
ABrow15
It turns out cmdtool2 is identical to megacli from LSI.
There is a debian repository at http://hwraid.le-vert.net/ HWraid
Problem solved (apart from the GUI, which won't install and isn't on the HWRAID site anyway)
