1. I have bought a motherboard S5000XVN, it says it is a form factor SCI EEB, is this the same as Extended ATX?
2. I have bought two CPU from different supplier one is
Prod code : BX80574E5410A
S-SPEC: SLANW
MM# : 894829
FPO/BATCH # : 3815B364
The other one is
Prod code: BX80574E5410A
S-SPEC:SLBBC
MM# : 898986
FPO/BATCH # : 3831A231
The question is can they go onto S5000XVNSATAR without problems?
The link in the last post dont have any info about the problem/question
I have the same question, with the same cpus (E5410, one step C0 and other E0) but with a mobo intel S5000vsasatar, its safe to use cpus of diferent steping on this mobo? and where can i get that kind of info? thaks and sorry about my english
Topic Options
