I have the opportunity to upgrade my S5520HCT based server with cheap Micron 32GB PC3-10600 DDR3-1333MHz ECC however I am not sure if it is possible to use 32GB DIMMs on this server board?
Has anyone successfully used 32GB DIMMs in the S5520HCT?
Norm
The largest memory module that Intel has validated for this board is a 16GB module. Intel always encourages our customers to use validated configuration to avoid unforeseen issues.
Intel offers a validation list as a reference of possible part numbers to use for your system.
http://www.intel.com/support/motherboards/server/s5520hc/sb/CS-030220.htm Tested Memory and Hardware List
Additionally, Intel has the http://imct.intel.com/ Memory Configuration Tool to assist you on the proper population based upon the board, and processor you have.
