Hello!, I'm trying to install an RS3DC080 RAID controller plus an AXXRMFBU4 BBU kit on a P4308XXMHGR+FCPUPMAD case.
Is there a supported/expected way to mount the capacitor plastic frame?
Hello CIria,
Thank you for joining the Intel community
The following documents are not specific for the AXXRMFBU4 BBU but the installation instructions holds.
Hope it helps
Jose A.
Thanks for answering, unfortunetly the capacitor cannot be mounted on the card. In the end found a spot at the botton (if you put the case horizontally) of the chassis that has the perfect spot (holes match the plastic box latches).
Hello CIria,
Good to hear that you found the correct place. Unless you have any other question we will proceed to mark this thread as resolved. If you have further issues or questions just go ahead and submit a new topic.
Regards.
Jose A.
![](/skins/images/3344F5B3B76C91485ED0E980FD0CA95E/responsive_peak/images/icon_anonymous_message.png)
