in java7 i placed ip of msc in exeption security list in java options but in java8 it does not help
i can't run kvm
help
Which specific version of Java are you using?
now version 8 update 45 the last version
in any browsers i can't run remote kvm session
i'm trying different PC's
especially for remote kvm i install in hyper-v winXP with IE 8 and java 7 build 1.7.0-b147 and its work!
Hi!
As we've not bumped into a similar scenario with Java 8, Update 45, and because, as we understand, you have already tried entering your RMM address into the Exception Site List, as outlined by our article# http://www.intel.com/support/motherboards/server/sb/CS-034679.htm CS-034679, we would appreciate if you could, please, provide more insight. For instance, what is exactly the error message you get? Would you, please, provide a screenshot?
Thx!
