Server Products
4872 Discussions
Installation Windows 10 auf S1200SPL mit RMS3CC080
ETrax
welche Treiber sind notwendig für die Installation von Windows10 auf einem Mainboard S1200SPL mit Raid Modul RMS3CC080?
Die Installation erfolgt von einer W10 Setup DVD, die Treiber möchte ich über den USB Stick laden.
Ich habe einiges von der Intel Downloadseite heruntergeladen, keines der Pakete liefert mit einen brauchbaren Treiber...
# intel_windows_drv_mr_6.714.18.00_pv
# rwc3_win_v007.017.011.000
# StorCLI_007.1704.0000.0000
BIOS: Advanced -> Mass Storage Controller Config -> SATA Port Config:
AHCI Contr.Config: 8 ports of 6Gb/s SATA
AHCI Capable SATA Controller   <RAID Mode>
AHCI Capable RAID Options       <INTEL(R) RSTe>
AHCI HDD Staggered Spin-Up   <Disabled>
SATA Port 0                    WDC WD10EFRX-6 - 1000.2 GB
SATA Port 1                    WDC WD10EFRX-6 - 1000.2 GB
SATA Port 2                    WDC WD10EFRX-6 - 1000.2 GB
SATA Port 3                    WDC WD10EFRX-6 - 1000.2 GB
SATA Port 4                    [Not Installed]
SATA Port 5                    [Not Installed]
SATA Port 6                    [Not Installed]
SATA Port 7                    [Not Installed]
Die Installation startet, kennt aber keine Laufwerke, das Laden der Treiber auf den o.a. Treiberpaketen bringt auchg keinen Erfolg.
Paul_R_Intel
Hello ETrax,
Thank you for joining the community,
I understand that you have been experiencing issues with the driver installation for the board Intel® Server Board S1200SPL after installing Windows 10.
Can you please provide a screenshot of the issue/error message that you received and which driver are you installing along with the installation?
In the following link you will find the available drivers for the Intel® Server Board S1200SPL:
In the following link you will find the available drivers for the Intel® Integrated RAID Module RMS3CC080:
Finally, did you try this driver:
Have you tried a different OS installation method like USB using Windows USB bootable device utility or other ISO?
Our support is only provided in English so your message has been translated. We apologize if any discrepancy.
If we do not hear back from you, we will follow up on 12/02dn
Paul R.
Intel Customer Support Technician
For firmware updates and troubleshooting tips, visit:
ETrax
Hi Paul,
thanks for your answer.
at first let me answer yor questions:
* setup esxi 6.7 with raid5 is configured works.
* setup windows10 with unconfigured raid (4 single drives) works.
* setup windows10 with raid5 is configured does NOT work.
on starting via windows installer dvd the drive cannot be found.
a alot of attempts with different downloaded driver packages failed:
intel_3108-mr_fwpkg-v24.21.0-0132.zip
intel_windows_drv_mr_6.714.18.00_pv.zip
rwc3_win_v007.017.011.000.zip
StorCLI_007.1704.0000.0000.zip
intel_chipset_win_10.1.18121.8164_pv.zip
intel_esrt2_1.60_win_drv_v18.01.2018.1107.zip
intel_vroc_win_6.2.0.1239_pv.zip
see in uploaded jpg's my last attempt
regards erich
Paul_R_Intel
Hello ETrax,
Thank you very much for all the information provided.
Lets try the steps found in page 17 section 5.5 thru page 19.
Please locate and use the folder called "iaStorE.free.win8.64bit.6.2.0.1238" . Located in the Intel® Virtual RAID on CPU (Intel® VROC SATA)/Intel® Rapid Storage Technology Enterprise (Intel® RSTe) Windows* Driver. That you have downloaded before from the following link:
Please let me know the outcome.
If we do not hear back from you, we will follow up on 12/06th
Paul R.
ETrax
Hello Paul,
your suggested solution was not successful.
I tried some more drivers i downloaded from intel download page, but none if the drivers could find my RAID disk.
Are there any dependencies on BIOS-setup?
In the uploaded ZIP file you can find screenshots from BIOS setup menu (BIOS*.jpg) and screenshots from installing windows10.
are there any other drivers neccessary for installation (mainboard-, raid-, ...drivers)?
I have no more ideas for continuing my windows installation....
regards erich
Paul_R_Intel
Hello ETrax,
I hope you are doing great thank you very much for the waiting time, after analyzing the screenshots provided, it looks like the Raid Controller is not in use, and you are using the Embedded SATA ports instead, I understand that the goal is to set up the raid 5 under the Intel® Integrated RAID Module RMS3CC080. Can you please make sure the RAID controller is configured correctly, here you have this guide:
Can you please tell us if you are using an Intel Chassis/Backplane and the model?
We continue to investigate this further and will make sure we provide a solution soon.
If we do not hear back from you, we will follow up on 12/09th
Paul R.
ETrax
Hello Paul,
have a lot of thanks for your information about configuring the raid controller (sasraid.html + serverbios)
this information helped me to setup the raid controller in the right way.
now the installation is running, the drivers you sent me can be loaded and ca find my raid driver.
And i canm see: with the right bios setup it's easy;-)
Thank you very much for your patience, i was on the wrong way with my setup procedure
regards
Erich
Paul_R_Intel
Hello ETrax
Thank you for your reply, we are glad to hear that this has worked and that the issues have been resolved, we will proceed to mark the thread as closed, if you have any further inquiry do not hesitate to contact us back. Thank you for choosing Intel.
Paul R.
