Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4657 Discussions
Intel S5520HC RAID configuration
RCruz9
Hello everyone !
I have a Intel Server Model S5520HC where RAID 1 array is set up
NO RAID
C: 500GB
RAID 1
D: 1TB | D: 1TB
E: 1TB | E: 1TB
Now I have a backup of D and E, if I change the 3TB HDD for about'll have no problem? with C which has RAID
raco,
The Intel® Server Board S5520HC has many RAID options available. I think if you look at the Intel® Server Board S5520HC http://www.intel.com/support/motherboards/server/s5520hc/sb/CS-030223.htm Technical Product Specification and the http://www.intel.com/support/motherboards/server/sb/CS-032920.htm Greater than 2 TB Drive Support for RAID Adapters and Onboard Server Board RAID website, you can find the information you're looking for. You might also want to view the http://www.intel.com/support/motherboards/server/sb/CS-022358.htm Server Products Intel® RAID Software Users Guide for additional information.
John
