I believe I may be missing a driver for the workstation motherboard but I am not sure which one. I am using Windows XP Professional. The device manager shows a driver is missing for the following: Intel 631xESB/6321ESB/3100 Chipset LPC Interface Controller - 2670. Any ideas on what this device is and how to locate this driver? Intel Deployment Assistant does not seem to help in the identification or problem resolution. If I let Windows Update search for the software, it cannot locate the driver either.
Try the latest http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18030&ProdId=2308&lang=eng Chipset Driver. Also make sure you install the http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17146&ProdId=2308&lang=eng TPM - Driver.
Thank you Edward. Installing the TPM driver resolved my problem!
