Server Products
4917 Discussions
Intel modular server and disconnected interfaces on server computer module
Hello, Recently We have got some problem with Intel modular server.
We have six server computer modules installed in Intel modular server, 2 switches, 2 scm.
We use external port 1 (vlan 1) of switch 1 to connect with our LAN.
So, if I turn on any server computer module and wait until OS(win 2008R2) boots completely, I'll see that interfaces related to LAN(vlan1) is disconnected, but other interface which related to other vlan is connected.
For example, server module 1 has two interfaces (Server1:Port1 and Server2:Port2) Server1:Port1 is in vlan 1 on Switch1, Server1:Port2 is in vlan 2 on the same switch.
To Intarface be connected, I have to do the following: Either pull out network cable from port external port 1 or switch Server1:Port1 from vlan 1 to any other vlan and then return back to vlan1
Ather that everything works fine until server computer module will be rebooted.
Can anybody explain me what it is?
Daniel_O_Intel
If you have spanning tree enabled, and accidentally create a network loop, spanning tree will disable one of the two ports. Since both ports go into the same switch, check the event logs and see if Spanning Tree is disabling one.
But it's edge port, only one server is conneted to this port. Also FastPort feature is enabled on the port.
Daniel_O_Intel
Did you check the Event Log, from within the management GUI?
