Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4661 Discussions
Is it possible to use the S1200BTL motherboard with SC5650 Server chasis
RRami11
Will the Intel S1200BTL motherboard physically work with the Intel SC5650 Server chasis? The recommended chasis for the S1200BTL does not have a redundant PSU and only four drive slots. Is there any downside to using the S1200BTL with the SC5650?
Thanks for any insight,
Robert
Daniel_O_Intel
Several downsides - it may not match the standoffs, the power supply may not be sufficient for continuous use, and the thermal requirements may be off.
Best to stick with the P4304XX series at http://www.intel.com/support/motherboards/server/s1200bt/sb/CS-032457.htm Intelhttp://www.intel.com/support/motherboards/server/s1200bt/sb/CS-032457.htm Server Board S1200BT — Tested chassis list
