Server Products
4784 Discussions
M10JNP2SB PCIe* Lanes Partition differs between Users Guide and Webpage?!
Sixi
Hi there Communtiy,
got a confusion with my M10JNP2SB Server Board. On the Webpage it says Max # of PCI Express Lanes : 8
In the User Manual theres a diagram showing that the PCIe* Ports #2 and #3 are both connected via PCIe* x8 Link. PCIe* Port #1 is connected via x4 Link through the Chipset.
So the questions is, how much PCIe* Lanes I can use with Port #2 and #3 since there is conflicting information. I Want to use the full x16 Ports across both PCIe* Slots (One HBA with x8 Link and one NIC with also x8 Link). Is this possible?
ManualManualWebSiteWebSite
Also M.2 Adapter x4 Link via Chipset would be nice, but i cant find information if Nvme is supported via PCIe* Adapter ?
Thanks for helping!
JoseH_Intel
Hello Sixi,
Thank you for joining the Intel community
According to ark the PCIe 3.0 ports available are 2 x8 ports and 1 x4 port. https://ark.intel.com/content/www/us/en/ark/products/197377/intel-server-board-m10jnp2sb.html
This matches with the info shown in Table 1 from section 2.1 of the Technical Product Specification: https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/m10jnp2sb-user-guide.pdf#page=12
PCIe* Add-in Card Slots
• Slot 1: PCIe* 3.0 x8 slot (x4 electrical)
• Slot 2: PCIe* 3.0 x8 slot (x8 electrical)
• Slot 3: PCIe* 3.0 x16 slot (x8 electrical)
So the configuration you want to attempt should be fine as long as you use PCIe ports 2 and 3 to install the HBA and NIC
Jose A.
JoseH_Intel
Hello Sixi,
I am just following up to double-check if you found the provided information useful. If you have further questions please don't hesitate to ask. If you consider the issue to be completed please let us know so we can proceed to mark this thread as closed. I will try to reach you back on next Monday 8th
Jose A.
JoseH_Intel
Hello Sixi,
We will proceed to mark this thread as closed. If you have further issues or questions just go ahead and submit a new topic.
Jose A.
