Server Products
4883 Discussions
Memory Bandwidth on HPC system
MChun4
Hi all,
I am having a problem with the performance of our system (256GB RAM, CPU E5-2680 v3 @ 2.50GHz, Xeon Phi 7200q). When I check the performance with Linpack tool, the result is not stable, sometimes it is dropped.
I debugged the tool and figured out the problem caused by Memory Bandwidth on NUMA model.
Node 19Numa node01058516.3886.2128470717.6
This is the result of one in our compute nodes. The bandwidth (MB/s) of memory on NUMA node 1 is very bad.
Can you give me some cases that you have experienced with this problem? Or, you can give me some recommends about the reasons which can be the cause of this problem.
Thank you!
Message was edited by: Minh Chung
We understand that you are having issues with memory. At this point what we would like to do is gather more information so we can proceed further on this matter. We sent you an email so you can reply back to us as soon as you can.
