Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4659 Discussions
R1000SPO server series rail options (R1304SPOSHORR rails)
GRIFFCOMM
Hi
Using the server configurator for the R1304SPOSHORR server i get the below rail:
AXXVPSRAIL (cheap one)
I notice under ARK for the above server i can use:
AXXPRAIL (quick fit and supports CMA (according to ARK here https://ark.intel.com/products/60268/1U2U-Premium-Rail-AXXPRAIL 1U/2U Premium Rail AXXPRAIL Product Specifications).
However the above AXXPRAIL doesnt have a listed part for the Cable Management Arm (CMA), i did find AXXCMA2 but this isn't listed to fit this rail, traveling around the internet i found this AXX1U2UCMA, i assuming this is the one for the AXXPRAIL?.
We have a 24 inch rack (609.6mm), so will the below work:
R1304SPOSHORR
AXXPRAIL
AXX1U2UCMA
Hi Griffcomm,
In regard to your configuration question, which the correct rails are for the Intel® Server System R1304SPOSHORR.
You are right, the proper rails for a rack of 609.6 mm are model AXXPRAIL and the compatible cable management arm is AXX1U2UCMA.
Please let me know if I can help you with anything else.
Mike C
Hi Griffcomm,
Mike C
GRIFFCOMM
Second part of this question then...
Will the below rails fit the server R1304SPOSHORR
A1UFULLRAILhttps://ark.intel.com/products/84772/1U-Premium-Rail-A1UFULLRAIL-with-CMA-support
We like the management AXXCMA2 but this will only fit the above rails...
Hi Griffcomm,
The rail 1U Premium Rail A1UFULLRAIL is intended for different models, the Intel® Server System R1304SPOSHORR requires the rail 1U/2U Premium Rail AXXPRAIL.
The https://ark.intel.com/products/84776/Cable-Management-Arm-AXXCMA2-Use-with-AXXFULLRAIL-only Cable Management Arm AXXCMA2 works on 2U server systems only.
Mike C
Hi Griffcomm,
I am following up your case. Please let me know if I can help you with anything else.
Mike C
