The reserve battery of cache-memory module AXXRPCM3 (RAID controller Intel SRCSASJV) as broken down.
Than it is possible to replace it (only the battery)? What analogue or compatible?
Thank's.
- Tags:
- Modules
You should be able to replace the cache memory module only; there is no need to replace the entire RAID controller for this.
You may also consider installing a Mini-DIMM module for caching purposes instead; and then, install a Intel® RAID Smart Battery AXXRSBBU3.
![](/skins/images/2F496A9BF2E73260E2FDFDBCABF91248/responsive_peak/images/icon_anonymous_message.png)
