Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4931 Discusiones
S1200BTLR & 460W Hot Plug Netzteil - PS2 working but not visible
Empleados
1.139 Vistas
Hello!
I have a new S1200BTLR with E3-1270v2 (last Bios 40) and a Intel Server Case P4308XXMHDR. The System ist working normal, but the hot plug PSU is not detected by IACS oder BMC. The BMC says PS1 - green - reports the power supply's presence has been detected reports there is a configuration error - Error 0x0041
The PSU an the Board ar connected trough ATX, CPU Power and 5-Pin P/S Connector
Both PS are working and can be changed, but I get no warning / info.
Has anyone an idea? Is the a special firmwar for the PSU / MB?
Greetings
Philipp
0 kudos
1 Responder
Edward_Z_Intel
Empleados
272 Vistas
This chassis is not designed to work with the S1200BTLR board. See http://www.intel.com/support/motherboards/server/s1200bt/sb/CS-032457.htm Tested chassis list.
Responder
