I googled but I did not find any accurate answer, I am planning on getting this server motherboard really cheap, and my only concern is if it will work with standard non-ECC memory.
Anyone who has this board did manage to get the motherboard working with regular DDR3 rams? Thanks!
- Tags:
- ECC Memory
Hello Federico,
Regarding your question, "S1200BT non-ECC RAM? ". Could you please provide us with a little more information on your question. For example, if the system board is able to manage Non-ECC RAM or if you could mix memory types.
Also the exact model on the system board, this is because there are several model:
But here is the Technical Product Specification for this model, http://download.intel.com/support/motherboards/server/sb/g13326007_s1200bt_tps_r2_4.pdf http://download.intel.com/support/motherboards/server/sb/g13326007_s1200bt_tps_r2_4.pdf. Memory information can be found on page 18, Memory Supported.
If there is anything else we can help please feel free to ask.
Henry A.
Hi thanks for your answer, I want to know if this motherboard is compatible with non-ECC memory modules.
The motherboard model is S1200BTS, that is what the sticker says
Hello Federico,
Thank you for the information. And according to the Technical Product Specification for this model, http://download.intel.com/support/motherboards/server/sb/g13326007_s1200bt_tps_r2_4.pdf http://download.intel.com/support/motherboards/server/sb/g13326007_s1200bt_tps_r2_4.pdf. Memory information can be found on page 18, Memory Subsystem and Memory Supported.
Only ECC memory is supported on this platform.
If there is anything else we can help please feel free to ask. Or this information has answered your question.
Henry A.
Hello Federico,
Henry A.
![](/skins/images/C4F7392A5C68ACA60290C9576F107044/responsive_peak/images/icon_anonymous_message.png)
Topic Options
