Hello myloveqiang,
"How to upgrade the BIOS on a S1400FP4".
You can download the latest BIOS from:
https://downloadcenter.intel.com/download/26964/Intel-Server-Board-S1400FP-Firmware-Update-Package-f... https://downloadcenter.intel.com/download/26964/Intel-Server-Board-S1400FP-Firmware-Update-Package-f...
Also, read the "Read Me.txt" file.
But also here are the steps:
- Unzip the contents of the update package and copy all files to a folder on a USB flash drive
- Insert the USB flash drive to any available USB port on the server system to be updated
- Boot the Server to the EFI shell. This can be accessed via the BIOS setup utility during POST.
- Run the command "map -r" in the EFI shell to mount the USB flash drive
- Run the command "fs0:" to change folders to the USB flash drive. The USB flash drive
may also mount to fs1: depending on other installed devices. The number of "fs# " is
dependent on the result of command "map -r"
- Change folders to the folder storing the update package files
- Run the command "Startup.nsh" to start updating all the firmware and BIOS updates
Warning:
!!Do NOT reboot or remove power from your system during the update process.
Doing so may render your system inoperable. !!
----- Verifying updates
- Reboot the system
- During POST, hit the Key when prompted to access the BIOS Setup Utility
- Hit the F9 key to load BIOS Defaults
- At the MAIN menu verify the BIOS revision is correct
- Move cursor to the SERVER MANAGEMENT Menu
- Move cursor down to the SYSTEM INFORMATION Option and hit Enter
- Verify the BMC Firmware revision is correct
- Verify the SDR revision is correct
- Verify the ME Firmware revision is correct
- Hit the F10 Key to save changes and Exit
If there is anything else we can help please feel free to ask.
Henry A.
Hello myloveqiang,
Warning:
- Reboot the system
Henry A.
Hello myloveqiang,
I am glad the information provided helped. If there isn't anything I can help I will proceed on closing the forum.
Henry A.
