The desktop and mouse pointer get stuck or freezes every 3-5 second.
And if a install Windows Server 2008 (not R2) it works fine until a install the chipset software (ver:9.1.1.1019) the a get the same problem.
/toli
I had the same problem, are you working with the onboard matrox G200 card? I think this is the problem (8mb's of video ram isnt enough), try to install a proper graphics card and report back please.
There's also a known issue in R2 with Intel NIC driver 14.2 and earlier. Install 14.4 or later (I think 14.6 is available now) and the problem should be resolved.
Hi
A think it´s 32mb of ram on s5500hcv.
After a installed a Nvidia card with 64mb it got better but not good.
So a reinstalled the onboard Matrox driver.
As suggested a updated the nic driver to 14.6 and then a played around with the SEWMDx64.exe inf tool for the Matrox card, and now it´s acceptable but not good.
A think this problem is a combination of different things, a hope the address this issue asap.
Thanks for your input in this issue.
Since we have the same problem, maybe we can compare our setup to find any similarities:
MB: S5520HC
CPU: 2x E5520
Ram: 6 GB Registered, ECC 1066 MHz
HDD: Intel X25-M 34nm postville 80GB SSD
SAS Card: Adaptec 5405
CD-ROM: Plextor 860SA
HDD Cage: Intel AXX6DRV3GR SATA SAS Backplane 6 drive hot-swap non expanded cage
Chassis: SC5650DP 600W PSU
Latest BIOS in M/B, SCSI controller, HDD Cage.
Latest Drivers from support site for Chipset, NIC, onboard Graphics, HDD Cage, SCSI Card
Windows 2008 R2
SSD/ CDROM --> AHCI Mode over the onboard intel controller
Hi
This is my setup.
MB: S5500HCV
CPU: 2x5504
RAM 6*Kingston KVR1333D3D8R9S-2 (12GB ram)
SAS: Intel SAS 8-port PCIe x8 SASUC8I
CD-ROM: DVD +-RW Samsung SH-223B SATA
HDD Cage: AXX6DRV3GEXP
Chassi: Intel SC5650DP 600W
HD: Am temporary using regular sata drive on the sas controller.
System BIOS - 42
BMC Firmware - 00.45
ME Firmware - 1.11
FRUSDR - 21
Hot-swap Backplane AXX4DRV3GEXP Firmware Version: v2.12
When a installed the matrox driver with "SEWMDx64.exe 2 8 1 1 1 1" it maid it better, but if this is the right way to do it a don´t know.
//Toli
Like Dan mentioned, this is a known issue caused by embedded NIC driver. You mentioned you installed driver 14.6, how did you do that? In my case I just ran the W2K8_R2-Win7_x64_Install.bat file in the intel-lan_msft_v14.6_whql.zip package and issue resolved.
Have you tried the 14.4 instead of 14.6 network drivers? Also have you installed manufacturer's x64 drivers for your mouse? I have searched a bit the internet and windows 7 have similar cursor problems.
Both 14.4 and 14.6 should fix the issue. It's not related to moue driver.
He's right. Try installing 14.6 but the using R2.bat, not the windows2008 one. and problem solved. thank you
Try to dissable the usb power savings! Picture got from last post of http://social.answers.microsoft.com/Forums/en-US/vistahardware/thread/7d9c89ad-0996-4ee0-a5e2-9591aa4d1f1b http://social.answers.microsoft.com/Forums/en-US/vistahardware/thread/7d9c89ad-0996-4ee0-a5e2-9591aa4d1f1b
![](/skins/images/045A6C88D0527A93E76B179D7F5E2AFE/responsive_peak/images/icon_anonymous_message.png)
