Server Products
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
4724 Discussions
Unable to share USB/floppy via RMM3
I'm having a strange problem on my Lenovo Laptop running Windows 7 32bit.
I am trying to share a USB disk on a RMM3 card, but when I click on Click:
Devices -> Share Floppy/USB key
It comes up and says there are no floppy/USB key visible in my computer. There is a USB key attached to my laptop, and the same USB key work fine from another system.
I have updated Windows 7 via Microsoft update, but am at a loss as to what I should do next.
Does anyone know of anything to try, or any logging to get to see what is going on?
cheers,
David
Hi All,
I was just wondering whether anyone else has had this problem, and found a solution for it.
regards,
David
Edward_Z_Intel
Do you mean you can share the same USB key from a different PC? Do you have latest Java installed? Perhaps it's related to the USB controller on your laptop...
