Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
Using SEL viewer on RHEL/SL6
DSpel
How do I get the SELviewer for S5520sc to run on a RHEL6-type Linux distribution? We have a fresh install of Scientific Linux 6 on an S5520sc board. The most recent instructions and downloads that I can find for Intel's SEL viewer for this model are here: http://www.intel.com/support/motherboards/server/sb/CS-031911.htm Intel® Server Boards — How to Extract and Read the Server Event Log (SEL). At launch, I'm getting the following error: /lib/ld-linux.so.2: bad ELF interpreter (it seems that cli requires libraries for xi686, which are incompatible with my system). Is there any update, or an alternative viewer? Many thanks.http://www.intel.com/support/motherboards/server/sb/CS-031911.htm Intel® Server Boards — How to Extract and Read the Server Event Log (SEL)http://www.intel.com/support/motherboards/server/sb/CS-031911.htm Intel® Server Boards — How to Extract and Read the Server Event Log (SEL)
Allan_J_Intel1
I have moved your post to the proper support group:
Allan.
David_A_Intel
It seems that this message was truncated. Let me check on this error and get back to you.
