Theoretically, working in Dual Channel Memory mode doubles the memory access bandwidth. I wrote that this is theoretically only because not in all system the bandwidth is doubled. Using this mode doesn't however affects (increases) the performance . Please read the following links for more detailed explanations:
- https://www.gamersnexus.net/guides/1349-ram-how-dual-channel-works-vs-single-channel?showall=1
- https://beebom.com/single-channel-vs-dual-channel-memory/
Leon
Hello Kline,
Thank you so much for contacting us about this concern.
I would like to double check if the information provided by Leon helped you in order to figure out the response that are looking for,
If not please do not hestiate and let me know in order to proceed with the next step.
Emeth O.
Under Contract to Intel Corporation.
Hello Dale,
I would like to know if you still need help on this?
If so, please do not hesitate and let me know and I will be more than happy to assist you.
Emeth O.
Thanks for your follow-up. I did read the articles that you attached, and the answer seems to be a ‘qualified’ YES – dual channel is faster… But there seems to be many factors, and the overall consensus seems to be that the speed increase depends mostly on the software running at the time. So I am just sticking with what I already gathered, that the dual channel memory will result in about 10% overall increase for our applications.
Thanks for your help,
Dale Kline | SAFARI Montage Hardware Integrator
SAFARI Montage
Five Tower Bridge
300 Barr Harbor Drive, Suite 700
West Conshohocken, PA 19428
P 610-645-4000
F 610-645-4040
dkline@safarimontage.com<mailto:dkline@safarimontage.com>
www.safarimontage.com<http://www.safarimontage.com/>
Hi Dale,
I am very glad to hear that, by any chance do you have any other question or concern in order to assist you with?
Emeth O.
Hi Dale,
Due to the fact that I have not seen any activity on this thread, I will proceed and close it.
Please if you have any other question do not hesitate and contact us back, and we will be more than happy to assist you.
Emeth O.
![](/skins/images/01F111D2651B8D490886918A505C4147/responsive_peak/images/icon_anonymous_message.png)
