Hi All,
I use C# wrapper of the SDK. Init goes all well but after receiving the first sample I receive a -301 error code from function
AcquireFrame(true);. In the documentation there is no reference why the error -301 or enum PXCM_STATUS_EXEC_ABORTED has been thrown.
Using the SDK logger I caught the following exception.
2016-10-03 10:26:57,151 rssdk.libpxccore (T-0x00003538) C:\Builds\2160\SW\src\_studio\core\core\src\corescheduler.cpp: 311 SyncPoint::SignalSyncPoint ERROR - sts = -3012016-10-03 10:26:57,151 rssdk.libpxccore (T-0x00003538) C:\Builds\2160\SW\src\_studio\core\core\src\corescheduler.cpp: 311 SyncPoint::SignalSyncPoint ERROR - sts = -3012016-10-03 10:26:57,151 rssdk.libpxccore (T-0x00003538) C:\Builds\2160\SW\src\_studio\core\core\src\corescheduler.cpp: 311 SyncPoint::SignalSyncPoint ERROR - sts = -3012016-10-03 10:26:57,151 rssdk.libpxccore (T-0x00003538) C:\Builds\2160\SW\src\_studio\core\core\src\corescheduler.cpp: 311 SyncPoint::SignalSyncPoint ERROR - sts = -3012016-10-03 10:26:57,151 rssdk.libpxccore (T-0x00003538) C:\Builds\2160\SW\src\_studio\core\core\src\corescheduler.cpp: 311 SyncPoint::SignalSyncPoint ERROR - sts = -3012016-10-03 10:26:57,151 rssdk.libpxccore (T-0x00003538) C:\Builds\2160\SW\src\_studio\core\core\src\corescheduler.cpp: 311 SyncPoint::SignalSyncPoint ERROR - sts = -3012016-10-03 10:26:57,151 rssdk.libpxccore (T-0x00002158) C:\Builds\2160\SW\src\_studio\core\core\src\corescheduler.cpp: 256 SyncPoint::SynchronizeExINT ERROR - Function Scheduler::SyncPoint::SynchronizeExINT returned sts = PXC_STATUS_EXEC_ABORTED (Execution aborted due to errors in upstream components)2016-10-03 10:26:57,151 rssdk.libpxccore (T-0x00002158) C:\Builds\2160\SW\src\_studio\core\core\src\corescheduler.cpp: 256 SyncPoint::SynchronizeExINT ERROR - Function Scheduler::SyncPoint::SynchronizeExINT returned sts = PXC_STATUS_EXEC_ABORTED (Execution aborted due to errors in upstream components)2016-10-03 10:26:58,288 rssdk.libpxccore (T-0x00002158) C:\Builds\2160\SW\src\_studio\core\core\src\corescheduler.cpp: 256 SyncPoint::SynchronizeExINT ERROR - Function Scheduler::SyncPoint::SynchronizeExINT returned sts = PXC_STATUS_EXEC_ABORTED (Execution aborted due to errors in upstream components)2016-10-03 10:26:58,288 rssdk.libpxccore (T-0x00002158) C:\Builds\2160\SW\src\_studio\core\core\src\corescheduler.cpp: 256 SyncPoint::SynchronizeExINT ERROR - Function Scheduler::SyncPoint::SynchronizeExINT returned sts = PXC_STATUS_EXEC_ABORTED (Execution aborted due to errors in upstream components)2016-10-03 10:30:05,816 rssdk.RealSenseDCMR200 (T-0x000031ac) D:\Builds\49\HiddenBuilds\src\_studio\service\RealSenseDCM\..\common/UnknownBase.h: 47 com::SafeExecuteEx ERROR - CameraException: -21474672592016-10-03 10:30:05,820 rssdk.libpxccamera_dcm_r200 (T-0x00001968) D:\Builds\49\HiddenBuilds\src\_studio\service\common/PxcSafeExecute.h: 19 SafeExecuteEx ERROR - lambda []()-><unknown-type>::operator()()-><unknown-type> @ "CaptureDeviceClient.cpp"(259) : (error 0x80004005) Unspecified error2016-10-03 10:30:05,833 rssdk.RealSenseDCMR200 (T-0x000031ac) D:\Builds\49\HiddenBuilds\src\_studio\service\RealSenseDCM\..\common/UnknownBase.h: 47 com::SafeExecuteEx ERROR - CameraException: -21474672592016-10-03 10:30:05,834 rssdk.libpxccamera_dcm_r200 (T-0x00001968) D:\Builds\49\HiddenBuilds\src\_studio\service\common/PxcSafeExecute.h: 19 SafeExecuteEx ERROR - lambda []()-><unknown-type>::operator()()-><unknown-type> @ "CaptureDeviceClient.cpp"(259) : (error 0x80004005) Unspecified error2016-10-03 10:30:05,919 rssdk.RealSenseDCMR200 (T-0x000031ac) D:\Builds\49\HiddenBuilds\src\_studio\service\RealSenseDCM\..\common/UnknownBase.h: 47 com::SafeExecuteEx ERROR - CameraException: -21474672592016-10-03 10:30:05,920 rssdk.libpxccamera_dcm_r200 (T-0x00001968) D:\Builds\49\HiddenBuilds\src\_studio\service\common/PxcSafeExecute.h: 19 SafeExecuteEx ERROR - lambda []()-><unknown-type>::operator()()-><unknown-type> @ "CaptureDeviceClient.cpp"(259) : (error 0x80004005) Unspecified error2016-10-03 10:30:05,939 rssdk.RealSenseDCMR200 (T-0x000031ac) D:\Builds\49\HiddenBuilds\src\_studio\service\RealSenseDCM\..\common/UnknownBase.h: 47 com::SafeExecuteEx ERROR - CameraException: -21474672592016-10-03 10:30:05,942 rssdk.libpxccamera_dcm_r200 (T-0x00001968) D:\Builds\49\HiddenBuilds\src\_studio\service\common/PxcSafeExecute.h: 19 SafeExecuteEx ERROR - lambda []()-><unknown-type>::operator()()-><unknown-type> @ "CaptureDeviceClient.cpp"(259) : (error 0x80004005) Unspecified errorI already tried removing en re-install the driver and SDK without any luck.
The camera that we use is a Intel Realsense R200 camera.
Are there any known issues related towards the USB connector ?
I have some USB3 connectors on my laptop but I don't know if the connector is able to deliver the power it
proberly needs.
I tested on my Desktop but with no luck, the camera won't init properly with a clean install.
I was only able to stream the color channel, adding more streams will cause the exception to appear.
Here is a snip of the code that I'm using:public void Start()
if (senseManager != null)
senseManager.Dispose();
senseManager = PXCMSenseManager.CreateInstance();
senseManager.EnableStream(PXCMCapture.StreamType.STREAM_TYPE_COLOR | PXCMCapture.StreamType.STREAM_TYPE_DEPTH, 0, 0);
var statusInit = senseManager.Init();
if (statusInit != pxcmStatus.PXCM_STATUS_NO_ERROR)
OnError("Camera kon niet gevonden worden of kan momenteel geen verbinding accepteren.", (int)statusInit);
return;
// Start the worker thread
processingThread = new Thread(new ThreadStart(ProcessingThread));
processingThread.Start();
This is probably due to the webcam bug Microsoft introduced in the Win10 Anniversary Update. Choose a lower resolution colour image for now (640*480 seems most stable), then you should be able to go back to full resolution when (if?) MS get around to fixing it.
