Software Archive
Read-only legacy content
Bug when using elemental functions and chars
leifblaese
 i have a small program using an elemental function to compute the edit distance of two strings:
[cpp]
__attribute__((vector))
int compare(char x, char y) {
    if (x == y) {
        return(1);
    } else {
        return(0);
int main()
    char a[3] = {'A','A','A'};
    char b[3] = {'A','A','A'};
    int c[3];
    for (int i = 0; i < 3; i++) {
        c = compare(a, b);
        cout << c;
    return 0;
[/cpp]
When compiling, i receive the following error message:
test.cpp: In function ‘__vector(4) int compare._simdsimd_B4m_v1(char, char)’:
test.cpp:9:5: internal compiler error: in convert_move, at expr.c:353
This does not happen, if i use an array of integers instead of chars.
I use the latest version of the gcc cilkplus-branch (checked out today).
regards
Milind_Kulkarni__Int
New Contributor II
hello, with Intel composer XE 2013 which also has Cilk, this issue does not come. which compiler did you check with? I am not sure we can do anthing with gcc cilkplus branch. though if you need more clarification, you can send the details for analysis.
