My build fails despite successful in attached log. What may be the cause? I use Construct 2.
- Tags:
- HTML5
- Intel® XDK
Two things that come to mind:
- did you "uncheck" the "signed" option in the build settings?
- how big is your project? greater than ~400MB can cause the builder to fail
How does the build fail?
Hmm, well it displays the 'Build Failed' text in orange, and it doesn't send the APK email it usually does. The log says the build succeeded, but also doesn't mention an APK that was built. It says...
Built the following apk(s):
...but then blank.
![](/skins/images/2E08A100FB92911314A240D1EAFB2828/responsive_peak/images/icon_anonymous_message.png)
Topic Options
