Please help. Does anyone encouter this?
$ cordova build
ANDROID_HOME=/home/hdc-126/Android/Sdk
JAVA_HOME=/usr/lib/jvm/java-8-oracle
Subproject Path: CordovaLib
null
The Task.leftShift(Closure) method has been deprecated and is scheduled to be removed in Gradle 5.0. Please use Task.doLast(Action) instead.
at build_b55i8ij3aqkypm9ge56hedqwj.run(/home/hdc-126/Desktop/Cordova_Project/EliteRX/platforms/android/build.gradle:138)
org.xwalk:xwalk_core_library:19+
The JavaCompile.setDependencyCacheDir() method has been deprecated and is scheduled to be removed in Gradle 4.0.
Incremental java compilation is an incubating feature.
The TaskInputs.source(Object) method has been deprecated and is scheduled to be removed in Gradle 4.0. Please use TaskInputs.file(Object).skipWhenEmpty() instead.
:preBuild UP-TO-DATE
:preDebugBuild UP-TO-DATE
:checkDebugManifest
:preReleaseBuild UP-TO-DATE
:CordovaLib:preBuild UP-TO-DATE
:CordovaLib:preDebugBuild UP-TO-DATE
:CordovaLib:checkDebugManifest
:CordovaLib:prepareDebugDependencies
:CordovaLib:compileDebugAidl UP-TO-DATE
:CordovaLib:compileDebugNdk UP-TO-DATE
:CordovaLib:compileLint UP-TO-DATE
:CordovaLib:copyDebugLint UP-TO-DATE
:CordovaLib:mergeDebugShaders UP-TO-DATE
:CordovaLib:compileDebugShaders UP-TO-DATE
:CordovaLib:generateDebugAssets UP-TO-DATE
:CordovaLib:mergeDebugAssets UP-TO-DATE
:CordovaLib:mergeDebugProguardFiles UP-TO-DATE
:CordovaLib:packageDebugRenderscript UP-TO-DATE
:CordovaLib:compileDebugRenderscript UP-TO-DATE
:CordovaLib:generateDebugResValues UP-TO-DATE
:CordovaLib:generateDebugResources UP-TO-DATE
:CordovaLib:packageDebugResources UP-TO-DATE
:CordovaLib:processDebugManifest UP-TO-DATE
:CordovaLib:generateDebugBuildConfig UP-TO-DATE
:CordovaLib:processDebugResources/home/hdc-126/Android/Sdk/build-tools/26.0.0/aapt: 1: /home/hdc-126/Android/Sdk/build-tools/26.0.0/aapt: Syntax error: ")" unexpected
FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':CordovaLib:processDebugResources'.
> com.android.ide.common.process.ProcessException: Failed to execute aapt
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 1.918 secs
Error: /home/hdc-126/Desktop/Cordova_Project/EliteRX/platforms/android/gradlew: Command failed with exit code 1 Error output:
* What went wrong:
* Try:
链接已复制
