Software Archive
Read-only legacy content
17060 Discussions
C# - SenseManager.StreamFrames(false) is not stopped by SenseManager.Close()
Pol_P_
I observed that when I use StreamFrames with a false flag my programs get stuck when I try to stop streaming frames.
According to the documentation StreamFrames method in SenseManager takes a boolean; true for blocking and false for non-blocking.
I am starting my stream like this:
_senseManager.StreamFrames(false);
and to stop it I call:
_senseManager.Close();
_senseManager.Dispose()
This hangs the program when the Close method is called.
However, if I create a new Thread and I call StreamFrames with a true flag everything works fine when I call Close and Dispose.
Something like this works fine:
Task.Factory.StartNew(() => { _senseManager.StreamFrames(true); });
Is this normal? Am I doing something wrong? I would like to call the non-blocking version of StreamFrames but also be able to Close it.
samontab
Valued Contributor II
This video may be of help. It explains how to access the raw frames in both modes:
https://www.youtube.com/watch?v=wIkIdjN6Oyw
Pol_P_
As I understand, my approach is exactly the same as the one proposed in the video.
The only difference I can see is that the video is using C++ instead of C#. This shouldn't make a difference however...
samontab
Double check the function names though. I remember there were a bit different in different languages. Something like Close in C++ vs CloseDown in C#, or something similar. Or maybe they changed that now.
Pol_P_
I just looked up the documentation and the function you have to call is called Close (same as in C++).
Here:
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/streamframes_pxcsensemanager.html
samontab
OK. If you did everything right there might be a bug in the C# implementation...
I guess Intel guys would need to have a sample code to check for this.
