Software Archive
Read-only legacy content
17060 Discussions
Can not install app on android 6
Ivan_M_1
I build android app in IntelXDK but can not install it on android 6.
I get installation screen but can not press "install " button.
It works perfect on android 5.
Under build settings target android API I put 23.
Can you help me with this?
John_H_Intel2
Can you send me a private message with the APK that you are trying to install so I can try it on an Android 6 device?
What device are you installing on?
Ivan_M_1
Just send you private message
John_H_Intel2
Downloaded your apk and installed it via ADB tools. It installed without a problem.
How are you trying to install it? OTA email link?
Can you send a screenshot of the screen you get stuck on as well as detailed steps as to what you are clicking on?
Can you create a new blank app, build that, and see if that installs without any modifications from you?
Ivan_M_1
Everything is ok.
Client had blue light filter installed on phone and that was issue :-(
Thank you for the support
John_H_Intel2
Thanks for the update!
