Software Archive
Read-only legacy content
17061 Discussions
Cilk on CentOS
newport_j
We had to make a major change and move from the Ubuntu operating system to CentOS (a version of Redhat). I am now tryng ti re-install Cilk ComposerC++ XE on CentOS.
It installed on Ubuntu, but installing on CentOS I have had some snags.
Please note thatthis is 64-biy CentOS, but I am installing 32-bit Cilk. The version is CentOS 6.2, 64 bit.
Idid have to make SeLinux permissive,and that worked. I contnued with the install andit said:
32-bit libraries not found on ths system
This product release the presenceof 32-bit compatibility libraries when running on Intel 64 architecture systems. One or more of these libaries could not be found:
libstdc+ (including libstdc++6)
glibc
libgcc
Without these libraries, the compiler will not function properly.
Now I can compile with the gcc command - no problem. During theinstall Iwas told that I had an unsupported operating system, but was given the choice to continue anyway. Since CentOS is Redhat Linux, I chose to ignore message and continue and until the error outlined above everything was okay.
Again, these points should be noted.
64-bit centos ver. 6.2
32-bit compiler for gcc, compiles easily with only gcc
but gave error outlined above during install.
Any help appreciated. Thanks in advance.
I saw something on the internet that the files might be there they just might not be linked.
Any thoughts on this?
Newport_j
newport_j
Nevermid this problem is solved.I just had to download one additional file. It worked.
Newport_j
Jose_F_
Hello Newport_j,
I have a similar problem now. I'm trying to install cilk in CentOS.
¿How did you solve your problem?
