Software Archive
Read-only legacy content
17061 Discussions
Confused With Integrating Admob from Intel XDK and Floatinghotpot
Olushola_O_
Please, I've been struggling with integrating admob into my apps..
Everytime I try to integrate admob into my app . I don't see any banners.But I notice in admob it says "Link App" I tried using the /cordova-admob-pro  in my app it doesn't work. I don't see any ad banners still . I usually embed the codes within a comment and after the close body tag.
My questions are:
1.If I want to use floatinghotpot's plugin , I download them as described from their source and embed the sample code in the position their example cited (below </body> tag) must I also tick the admob plugin from intel xdk?
2.I use floatinghotpot because they have option for admob for Windows Phone 8, Should I leave this external plugin and live with the one provided in intel xdk that supplies only for Android and IOS .
Thanks for your time.Please see my code below (Or should I put the <script>codes between my header tags  ?). Am veery confused
    </body>
    <!--Start As for Admob Test-->
    <script>
var admobid = {};
if( /(android)/i.test(navigator.userAgent) ) {
    admobid = { // for Android
        banner: ' ca-app-pub-9089133254696423/9109051197',
        interstitial: 'ca-app-pub-9089133254696423/4105271992'
} else if(/(ipod|iphone|ipad)/i.test(navigator.userAgent)) {
    admobid = { // for iOS
        banner: 'ca-app-pub-6869992474017983/4806197152',
        interstitial: 'ca-app-pub-6869992474017983/7563979554'
} else {
    admobid = { // for Windows Phone
        banner: ' ca-app-pub-9089133254696423/5582005196',
        interstitial: 'ca-app-pub-9089133254696423/7992244796'
function initApp() {
    if (AdMob) {
        AdMob.createBanner({
            adId : admobid.banner,
            position : AdMob.AD_POSITION.BOTTOM_CENTER,
            autoShow : true
document.addEventListener('deviceready', initApp, false);
</script>
    <!--End As for Admob Test-->
</html>
 </body>
    <script>
var admobid = {};
} else {
    if (AdMob) {
            autoShow : true
</script>
</html>
Josef_J_
I use admob pro as well ( com.google.cordova.admob ) and use the exact code as above  after the </body> tag .
it should work fine , when you test the apk file ( on device) before you upload it you should see ads immediately but for the results to show in your admob account, it takes few hours .
