I'm currently having an issue with uploading multiple APKs with Crosswalk 15 and Cordova CLI 5.1.1. When I try to upload the x86 apk it shows the same architecture as its ARM counterpart: arm64-v8a, armeabi, armeabi-v7a, x86, x86_64 which causes an error.
I'm wondering if there is a solution for this?
Nick
連結已複製
good news!
I removed the SQL Plugin (version 0.7.10) and reinsert the same with version 0.7.11 (the change of version does not work; it is necessary to remove and to insert).
After rebuild with this change and... it works! Google Play accept the 2 APKs normally.
Paul> another news, good one but very odd. Building the same app for iOS with sqlite 0.7.11 occurs an error. Then I downgrade to 0.7.9 and build OK.
In short:
- to have 2 valid APK to Android I need to use sqlite 0.7.11
- to build successfuly to iOS I need to use sqlite 0.7.9
Hamilton, that plugin author has made several new releases. You might try using the third-party plugin dialog to add the latest version. You can do that this way (best to first uninstall the existing version):
