Software Archive
Read-only legacy content
Crosswalk build with App Security API issue
Sam_Deepak
If I add App Security API plugin in build settings in 2323 version of XDK, the crosswalk app in android while opening, it alerts "Unfortunately, App has stopped".
I thought, there may be problems in my code, but I tried creating a empty app just with this plugin, still I am getting the same error.
Could somebody please help me.
Sam Deepak.
John_H_Intel2
Are you installing the correct apk from the crosswalk build on your device?
Sam_Deepak
Yes, I am installing x86 apk to my intel ASUS phone. It installed , but while opening, it prompts, "the app has stopped unexpectedly".
But if I remove App security API.build it and install it, I dont get any problems. I tried with an empty app with just this plugin, it is giving this problem. I am confused.
Sam Deepak.
John_H_Intel2
I just built an very simple crosswalk build and installed the ARM version on my samsung s4. It installed/launched with no issues with the Security API included.
Try installing the ARM version from the attached zip. If you are still having issues, attach the zip you get from the build system to your post.
Sam_Deepak
HI,
Actually my phone requires x86 version, but neither versions worked, I have attached a simple app with APP security API included. See if you can find out anything wrong in what I did.
Sam Deepak.
PaulF_IntelCorp
@Sam -- I tried the examples you provided and the x86 fails on my Asus x86 device, but the ARM works on my Samsung S3. Can you attach a copy of the <project-name>.xdk file from the root of the project directory AND the intelxdk.config.crosswalk.xml files from the project you used to build this example? I want to see which version of the App Security API plugin is being included.
PaulF_IntelCorp
After you post the files I requested, can you try another experiment -- build a single app using the "shared" option in the "Crosswalk Runtime" field on the Projects tab (in the Build Settings). See if that APK will run:
Sam_Deepak
I have tried it with Share option. It did not work. I have attached .xdk file and  intelxdk.config.crosswalk.xml file herewith. Please review them.
Sam Deepak.
PaulF_IntelCorp
I'm sorry, I meant for you to add the security plugin and build it and install it to confirm that this simple app results in a failure. Then send me the two files above. I don't see the security plugin being used in the files you sent me, the app is including the device, splashscreen and inAppBrowser plugins...
Sam_Deepak
I was a mistake from me that I attached wrong files, now I have attached correct .xdk file and  intelxdk.config.crosswalk.xml file herewith. Please review them.
Sam Deepak.
PaulF_IntelCorp
Nothing odd in those files. I tried to reproduce this with a simple project of my own and I cannot create a build that fails. Can you ZIP the entire project directory for a project that causes this and attach it to a post on this thread. There must be something else going on in the project that is causing this.
Sam_Deepak
Hi Paul,
Attached is the zip file containing the complete project.
Sam Deepak.
PaulF_IntelCorp
Can you please include the AppSecurity.xdk file? This is an important file...
Sam_Deepak
Hi Paul,
Attached is the zip file containing the correct project files
Sam Deepak.
PaulF_IntelCorp
When I build that app, exactly as you have given it to me, no changes to anything, and install and run it on an x86 and an ARM device it works, there is no crash. I've attached the builds that I installed. Please let me know if these crash on your devices.
Sam_Deepak
Hi Paul,
I am getting the same error even after I installed the version of the apk files given from you. I really dont now why is ths.
Sam Deepak.
John_H_Intel2
Sounds to me like it is a device issue. Do you have another android device to test it on?
Sam_Deepak
Hi John,
I will have access to some other android device in another 2 hours, so I will update you in 2 hours. But my concern is, previously it was working before switching to 2323 build of XDK.
Sam Deepak.
PaulF_IntelCorp
This is very strange...
Make sure you have removed any existing installs of the application before you install the copies I gave you, to be sure the new version actually got installed. I have seen situations where installing over the top of an existing app fails, but not in an obvious way. So UNINSTALL the existing test apps on your device and then install the x86 version I sent to you.
The version of the XDK does not change how the build works, since the build server is in the cloud and is not tied to the version of the XDK.
Could you please also try installing the EA version of the XDK and perform the same test with a project built from that version. In that case the build will be affected because the plugins are provided by the XDK rather than retrieved by the build system, otherwise the builds are the same. See these posts for details:
Sam_Deepak
Hi Paul,
I am downloading XDK EA now, once I tried creating an empty app with App Security API in XDK EA, I will update you back right then.
Sam Deepak.
Sam_Deepak
Hi John,
I tried it in some other device also, the same crash occurs there also. Could you please advice.
Sam Deepak.
