Software Archive
Read-only legacy content
17061 讨论
DTDs in [NonEDIDMode_AddSwSettings] section for 945GM
eschek
初学者
404 次查看
PROBLEM SOLVED WITH ARCHIBAELS METHOD! BIOS WAS NOT ALLOWING ME TO SELECT THE DESIRED RESOLUTION
Hi!
I have a Fujitsu AMILO SL T3230 (23 inch) TFT connected to my Toshiba Portege M500 and want to use the 1920 x 1080 resolution at 60Hz.
When I go to Display Settings with "Hide modes that this monitor cannot display" unchecked 1920x1080 is not available.
There is only either 1680x1050 or 1920x1200. Currently I am using 1680x1050.
Could you please provide me with the DTD Setting for 1920 x 1080 at 60Hz as I am not knowledgeable in terms of editing INF files?
Additional info:
When I open the igdlh.inf which can be found when downloading the display drivers from the Intel homepage there is actually a DTD line for "1920x1080@60...Interlaced". So i changed "TotalDTDCount" from 0 to 5 and rebooted. Now I do have 1920x1080 but only with 25Hz Interlaced and 30 Hz Interlaced.
Currently [NonEDIDMode_AddSwSettings] looks like this:
HKR,, TotalDTDCount, %REG_DWORD%, 0 ; This shows number of DTDs to be used. ; 0-->Disable the feature.
;Following keys have 20 bytes (18 byte DTD + 2 Byte flags).
HKR,, DTD_1,%REG_BINARY%, 01,1D,80,18,71,1C,16,20,58,2C,1A,00,00,00,00,00,00,86,37,01 ;1920x1080@60...Interlaced
HKR,, DTD_2, %REG_BINARY%, 01,1D,80,D0,72,1C,16,20,10,2C,1A,80,00,00,00,00,00,86,37, 01 ;1920x1080@50...Interlaced
HKR,, DTD_3,%REG_BINARY%, 01,1D,00,BC,52,D0,1E,20,B8,28,25,40,00,00,00,00,00,04,37, 01 ;1280x720@50....Non-interlaced
HKR,, DTD_4, %REG_BINARY%, 01,1D,00,72,51,D0,1E,20,6E,28,25,00,00,00,00,00,00,06,37,01 ;1280x720@60....Non-interlaced
HKR,, DTD_5,%REG_BINARY%, 00, 00, 00 ,00, 00, 00,00, 00, 00,00, 00, 00,00, 00, 00,00, 00, 00,00, 00 ;Fifth DTD
I got the idea to edit the DTD setting to get my desired 1920x1080 result from the following threads:
http://software.intel.com/en-us/forums/showthread.php?t=53239
http://www.mp3car.com/vbulletin/lcd-display/100995-800x480-intel-945gm-gma950-possible-3.html
Thanks in adavance.
Additional info concerning my specs:
Intel Graphics Media Accelerator Driver for Mobile Report
Report Date: 08/07/2009
Report Time[hr:mm:ss]: 15:17:15
Driver Version: 7.14.10.1504
Operating System: Windows Vista Business* , Service Pack 2 (6.0.6002)
Default Language: Korean
DirectX* Version: 10.0
Physical Memory: 3062 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 256 MB
Graphics Memory in Use: 135 MB
Processor: x86 family 6 Model 14 Stepping 12
Processor Speed: 1862 MHZ
Vendor ID: 8086
Device ID: 27A2
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Mobile Intel 945 Express Chipset Family
Video BIOS: 1358
Current Graphics Mode: 1680 X 1050 True Color (60 Hz)
* Devices Connected to the Graphics Accelerator *
Active Monitors: 1
Non Active Notebook Displays: 1
* Monitor *
Monitor Name: AMILO LSL 3230T
Display Type: Analog
Gamma Value: 2.20
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: 20.0 inches
Vertical: 11.0 inches
Monitor Supported Modes:
640 X 480 (60 Hz)
640 X 480 (75 Hz)
720 X 400 (70 Hz)
800 X 600 (60 Hz)
800 X 600 (75 Hz)
1024 X 768 (60 Hz)
1024 X 768 (75 Hz)
1280 X 1024 (60 Hz)
1280 X 1024 (75 Hz)
1440 X 1440 (60 Hz)
1600 X 1200 (60 Hz)
1680 X 1680 (60 Hz)
1920 X 1080 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Supported
* Notebook *
Monitor Name: Generic PnP Monitor
Display Type: Digital
Gamma Value: 3.54
Maximum Image Size: Horizontal: Not Available
Vertical: Not Available
1280 X 800 (60 Hz)
This is a screenshot from powerstrip. Maybe this helps.
0 项奖励
0 回复数
回复
