Software Archive
Read-only legacy content
17060 Discussions
Default template give me error "Do you have index.html in your source directory?"
RAJU_P_
I created new project with default template Html5 + Cordova and run emulate it give me below error message. Do you have index.html in your source directory?
Ad
New Contributor III
I have tried reproduced it: Start New Project -> Templates -> Blank -> HTML5+Cordova -> use App Designer
Result: Emulator is showing me the index.html = white screen
Q1: Did you install XDK in a non-default location?
Q2: Can you try some other demo projects and see if you are having the same issue?
Q3:  Are you using a tablet with App Preview opened
John_H_Intel2
What build of the XDK do you have installed? Top right corner.
PaulF_IntelCorp
This thread appears to be having the same problem: https://software.intel.com/en-us/forums/topic/583864
