Software Archive
Read-only legacy content
17061 ディスカッション
Evaluation version of XE 2015 requires license
jpanta
ビギナー
2,188件の閲覧回数
I was able to compile in 32-bit but not in 64-bit, due to a license issue (see below). This is the evaluation version (of XE Composer 15) I downloaded a few days ago.
Anyway, to work around this quickly?
Thank you in advance.
1>------ Build started: Project: ***************, Configuration: Release x64 ------
1>
1>  Error: A license for CCompW is not available (-158,61003,2).
1>
1>
1>  License file(s) used were (in this order):
1>
1>      1.  Trusted Storage
1>      2.  C:\Program Files (x86)\Common Files\Intel\Licenses\*.lic
1>      3.  C:\Program Files\Common Files\Intel\Licenses
1>      4.  C:\PROGRA~2\Intel\COMPOS~1\bin\Intel64\*.lic
1>
1>
1>  Please visit http://software.intel.com/sites/support/ if you require technical assistance.
1>
1>
1>icl: : error #10052: could not checkout FLEXlm license
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
0 件の賞賛
15 返答(返信)
TimP
名誉コントリビューター III
2,188件の閲覧回数
The same license which works for the 32-bit compiler should work also for 64-bit.  Just copy it into the folder designated at 2.   This should have been taken care of during installation.
If you need help from an Intel person with access to the registration data, the companion forum on licensing should work faster.
jpanta
ビギナー
2,188件の閲覧回数
Right, I will check at the accompanying forum. For the record, I am not sure what I should be looking for (for the 32-bit license).
Thank you.
KitturGanesh
従業員
2,188件の閲覧回数
BTW, you can set the INTEL_LICENSE_FILE to the full path where the license file exists like:
%INTEL_LICENSE_FILE=~/x/y/z/xxx.lic
and then try it out it. In the meantime, I'll transfer this to the correct forum who can look at the license and validate etc and address your issue at: https://software.intel.com/en-us/forums/intel-software-development-products-download-registration-licensing
_Kittur
jpanta
ビギナー
2,188件の閲覧回数
Thank you, I hope it is ok because I had already posted here...
To get things right though:
I don't have a license sent with the evaluation version. Making a search on the c drive revealed no license (except for one old commercial one, not evaluation).
Question remains how to compile 64 bit, why the compiler makes that license request being on evaluation?
Any work around?
QIAOMIN_Q_
新規コントリビューター I
2,188件の閲覧回数
    I will send you the license file to your registered email, please have a check.
Thank you.
QIAOMIN.Q
Intel Developer Support
Please participate in our redesigned community support web site:
User forums:                   http://software.intel.com/en-us/forums/
jpanta
ビギナー
2,188件の閲覧回数
I am sorry, but how am I supposed to do that? Is there a recommended link for downloading flexim license server?
jpanta
ビギナー
2,188件の閲覧回数
FYI, I have found this related direct download link: https://software.intel.com/en-us/articles/performance-tools-for-software-developers-intel-flexlm-license-servers But I get an error clicking on the link above. It may be available only for licensed users and not evaluation? Thanks
Deepanshu_S_
ビギナー
2,188件の閲覧回数
I have installed Intel Composer XE 2015 evalaution product.
But I cannot find the lincense file inside C:\Program Files (x86)\Common Files\Intel\Licenses.
Please send me the license file for the same.
thank you
QIAOMIN_Q_
新規コントリビューター I
2,188件の閲覧回数
Hello, Deepanshu
Please tell me of you serial number by sending me a private message, I'd like to send the file to you.
Best,
Qiao
Duc_An_H_
ビギナー
2,188件の閲覧回数
Dear Sir/Madame, I am using an evaluation copy of Intel Fortran Compliler in order to run subroutine in Abaqus. However, I encountered a problem while using Intel Fortran Composer with the message below: " Error: A license for FCompW is not available (-158,61003,2). License file(s) used were (in this order): 1. Trusted Storage 2. C:\Program Files (x86)\Common Files\\Intel\Licenses\*.lic 3. C:\Program Files (x86)\Common Files\Intel\Licenses\*.lic 4. C:\Program Files\Common Files\Intel\Licenses 5. C:\PROGRA~2\Intel\COMPOS~2\bin\intel64\*.lic ifort: error #10052: could not checkout FLEXlm license Abaqus Error: Problem during compilation - std_user.for Abaqus/Analysis exited with errors " Could you kindly send me a temporary licence for evaluation version. Thank you in advance. Best regards, Duc An Ho Mail: hoducan@gmail.com
Duc_An_H_
ビギナー
2,188件の閲覧回数
Hubert_H_Intel
従業員
2,188件の閲覧回数
License file sent to your email address.
Regards, Hubert.
fwefew
ビギナー
2,188件の閲覧回数
Mohammed_K_
ビギナー
2,188件の閲覧回数
I've downloaded an evaluation version of the Intel System Studio Ultimate Edition. I've been on search for the license file for hours. Would you please email it to me at mghiathk@gmail.com
It is a Linux 64-bit version. I appreciate your prompt response and thank you in advance.
Thanks!
QIAOMIN_Q_
新規コントリビューター I
2,188件の閲覧回数
Hello Mohammed,
The license file has been sent ro your registered email.
Thank you.
QIAOMIN.Q
返信
