Software Archive
Read-only legacy content
17060 Discussions
Explanation of how node-locked licenses works with new licensing?
AndrewC
New Contributor III
I am looking for an explanation of how Parallel Studio XE 2016 compiler licensing now works for renewals of 'existing' node-locked licenses.
For example, I just installed XE 2016 on a windows machine with 3 ethernet adapters.
In the license management for my serial #, it shows 3 adapters host IDs ( of my 3 adapters). And no way to manage them?
Frankly, the new licensing is a real PITA. This is a big backward step.
AndrewC
New Contributor III
For testing purposes I installed Parallel Studio 2016 on another machine. This machine now shows up on a separate line  in the license management page as a new 'host'.
But there is no way to delete a 'host'?  How do I delete a machine that is no longer being used for development.
Devorah_H_Intel
As you correctly noticed, the installer recorded all the MAC addresses on the single system under one host. You can install on up to 3 systems. To remove the host from Registration Center you can submit a request here on the forum or submit an IPS ticket.
https://software.intel.com/en-us/articles/what-to-do-when-you-see-the-message-maximum-number-of-activations-exceeded
AndrewC
New Contributor III
PM sent to remove host
Devorah_H_Intel
This issue has been resolved. If you have a similar issue, do not add it to this thread but start a new one.
