- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Hello, Please help, when sewing devices computer crashes, how to restore the firmware on Xeon Phi 5110p?
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I'm not sure I quite understand what you are saying. The micinfo command will not show the flash or SMC versions if the coprocessor is not booted. So, in this case, the output from the micinfo command does not actually mean that the that the flash or SMC are wrong or missing. Can you tell us more about what commands you ran and what you saw when the computer crashed? (Was that the host computer?)
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
after the last message, I did the following.
1) The server is overloaded
2) made as written readme.pdf item 3.1
3) after flashing, I was asked to press Y to restart after a reboot I got here such data, say all was OK with my device?
Device No: 0, Device Name: Intel(R) Xeon Phi(TM) Coprocessor
Version
Flash Version : 2.1.02.0386
uOS Version : 2.6.38.8-g5f2543d
Device Serial Number : ADKC25104470
Board
Vendor ID : 8086
Device ID : 2250
Subsystem ID : 2500
Coprocessor Stepping ID : 3
PCIe Width : x16
PCIe Speed : 5 GT/s
PCIe Max payload size : 256 bytes
PCIe Max read req size : 512 bytes
Coprocessor Model : 0x01
Coprocessor Model Ext : 0x00
Coprocessor Type : 0x00
Coprocessor Family : 0x0b
Coprocessor Family Ext : 0x00
Coprocessor Stepping : B1
Board SKU : B1PRQ-5110P/5120D
ECC Mode : Enabled
SMC HW Revision : Product 225W Passive CS
Core
Total No of Active Cores : 60
Voltage : 0 uV
Frequency : 1052631 kHz
Thermal
Fan Speed Control : N/A
SMC Firmware Version : 1.8.4326
FSC Strap : 14 MHz
Fan RPM : N/A
Fan PWM : N/A
Die Temp : NotAvailable
GDDR
GDDR Vendor : Elpida
GDDR Version : 0x1
GDDR Density : 2048 Mb
GDDR Size : 7936 MB
GDDR Technology : GDDR5
GDDR Speed : 5.000000 GT/s
GDDR Frequency : 2500000 kHz
GDDR Voltage : 0 uV
I have some reason the blue LED flashes on my device (
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
which team can test my device?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Your output from micinfo looks ok to me. It is normal for the blue light to flash when the card is powered up.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
When was the version of Flash versioning: 2.1.02.0375
I wrote micctrl --start and the blue LED was on all the time, but now that I did not do it constantly flashes
now look in the console dialogue:
PS C:\mpss\bin> micctrl --start
Option '--start' is not allowed when Intel (R) Xeon Phi (TM) service is running
PS C:\mpss\bin> micctrl -s
mic0: ready
PS C:\mpss\bin> micinfo
MicInfo.exe
Version: 6720-12
Copyright 2011-2013 Intel Corporation All Rights Reserved.
MicInfo Utility Log
Created Fri Jul 19 04:54:38 2013
System Info
Host OS : NotAvailable
OS Version : Microsoft Windows 6.2.9200.2
Driver Version : 2.1.6720.12
MPSS Version : 2.1.6720.12
Host Physical Memory : 17122 MB
*************************** The information below is not complete **************************
****** Please start the MPSS service and run MicInfo again to view the entire output *******
Version
Flash Version : NotAvailable
uOS Version : NotAvailable
Device Serial Number : NotAvailable
Board
Vendor ID : 8086
Device ID : 2250
Subsystem ID : 2500
PCIe Width : x16
PCIe Speed : 5 GT/s
Board SKU : NotAvailable
ECC Mode : NotAvailable
SMC HW Revision : NotAvailable
Core
Voltage : NotAvailable
Frequency : NotAvailable
Thermal
Fan Speed Control : NotAvailable
SMC Firmware Version : NotAvailable
FSC Strap : NotAvailable
Fan RPM : NotAvailable
Fan PWM : NotAvailable
GDDR
GDDR Vendor : NotAvailable
GDDR Version : NotAvailable
GDDR Density : NotAvailable
GDDR Size : NotAvailable
GDDR Technology : NotAvailable
GDDR Speed : NotAvailable
GDDR Frequency : NotAvailable
GDDR Voltage : NotAvailable
PS C:\mpss\bin>
instead of the data I get is that the device is off like, or what I do not understand? (
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I recently bought a Xeon Phi and want to find out it works with me or not, how to check?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
GDDR Voltage : 0 uV
Is this normal?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
The Intel(r) Xeon Phi(tm) coprocessor service on your server is running (I know this because when you type "micctrl --start", you get "Option '--start' is not allowed when Intel (R) Xeon Phi (TM) service is running") but the Linux kernel on the coprocessor is not running (I know this because when you type "micctrl -s", you get "mic0: ready".) There are a number of ways this can happen. The most common way is if you typed "micctrl -r" at some point.
To restart the operating system on the coprocessor, you can either start the coprocessor directly ("micctrl -b" - this works as long as the service is running) or you can stop and restart the service ("micctrl --stop" then "micctrl --start").
You seem very frustrated at this point. I would strongly recommend reading the Intel Xeon Phi Coprocessor Developer’s Quick Start Guide for Windows* Host and I will see if I can find someone to give you more help.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
After talking to the developers, they recommend that you go to the section 3 of the readme and repeat steps 1 to 8 as shown. I know you have already gone through this once but if you could repeat the steps, then get back to me, I would appreciate it.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thank you so much that you do not forget about me)
1) I tested your examples that come with the compiler. Everything is fine.
2) what do you suggest I will do and I will write here.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Good afternoon, workers Intel Please look at my example and tell me whether I'm working with Xeon Phi.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Just to close out this issue - it did appear that the coprocessor was functioning. The examples referred to appear to be in https://software.intel.com/en-us/forums/topic/402285 and are addressed there.
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
