Software Archive
Read-only legacy content
17060 Discussions
Hi-res voxel/mesh in RF_ScenePerception (R200 c++)?
Finfa811
Hi all,
Is there any way to set high resolution voxel/mesh in RF_ScenePerception?
No matter how I play with rgb & depth width/height, same output is returned (lo-res mesh). Btw, is there still any driver limitation so we can't use 640x480x60 depth resolution?
Cheers.
Finfa811
Thanks for your reply. I have already fixed it.
SetVoxelResolution does the trick, there are three different levels of resolution. Then I had to deal with some issues to improve the tracking, but finally I'm able to reconstruct a mesh at rgb640x480/depth480x360/fps60 with high detail (I've changed default QVGA configuration).
Still I don't know why I can't use VGA depth mode, I've tried with different examples (including the sample app) and it crashes. Maybe not yet available?
Xusheng_L_Intel
I can use high resolution with our sample app. The sample use QVGA depth image to increase the range. Could you provide more info about your issues? Thanks!
Finfa811
