If you are referring to the "web services" feature on the Develop tab, all the files associated with those web services (that you created) are stored in your project directory. Normally in the "www/xdk/services" folder. Deleting those files from that folder would delete any "web services" stored in your project.
If that is not what you are asking, please provide more details regarding the issue you are trying to resolve.
Is the request being cached? Is that the problem?
Could you explain what it is you are trying to do? That would help
I try doing a project that take username and password. I reach an url that include JSON code with using username and password parameters. When I thrutly entered true username and password one time it is go and take JSON code. This is fine. but second time I enter the wrong password or username my app is go the first entered url. It must give me wrong password or username alert but cause of url is recorded somewhere in web service it is not give me alert. My code is following
$.getJSON( "blablabla...scenes&txtEmail="+ formUsername +"&txtPassword="+ formPassword,function(jsondata){ if(jsondata == null){ alert("Wrong password or user name please try again!"); }else{ intel.xdk.services.LNLAyatar3Bolge({scenes:"", txtEmail:formUsername , txtPassword:formPassword, p1:"4"}) .then(function(data){ console.log("here is the data from the service", data); }) return; } });
// "blablabla...scenes&txtEmail="+ formUsername +"&txtPassword=" is my url
The other words when I enter wrong username or password in first time it is give me alert wrong username or password. Then I entern true user name and password it is call truthly and then I entern wrong input it is call true url again. it mustn't be.
The action like that:
1st İnput --> wrong
My App --> alerted wrong input
2nd input --> wrong
My App -->alerted wrong input
3rd input --> true
My App --> right entry
4th input --> true
5th input --> wrong
6th input --> wrong
7th input --> wrong
8th input --> true
9th input --> wrong
My App -->right entry
10th input --> wrong
so After I entered true username and passwrod for one time, My password and username is whether true or false, it is not matter my app is call first entered true url. I try to balk it.
Hİ,
That is not I wanted. I want to delete username and password that token from user and using web service, after using. I want to do it cause of: Username and password is entered wrongly web service is use first true username and password after username and password entered turthly one time. How can I inhibit it?
Yes the request being cached and it is problem for my project. I try do delete taken request from user after user log out. can I do it? Please help me.
Well, I'm still not completely clear on what's going one, but the service request has the same options as the jQuery Ajax call.
So, you can go to the service call and add cache:false to the options.
intel.xdk.services.LNLAyatar3Bolge({cache:false, scenes:"", txtEmail:formUsername , txtPassword:formPassword, p1:"4"}.then(function(data){
Does that help?
Does that help?
Unfortunatly, it isn't help to me. I want to logout from an account but it is not work on it :(
Ok, I think I understand.
If this is a service you wrote yourself, then go into the service and add a call to dispose of any of the login data that is in the closure.
If this binding is one of our services, then you'll have to dive into service-methods.js, find it, and do the same. That will be considerably harder. I will look into our OAuth exposing services and see if we can expose a routine that will dump the access tokens.
Chris Thank you for helping but my problem is on the my service that writen in php language(not in intel xdk). I add a logout method and I call it from index.html. To sum up I can logout from account.
Have a nice day :)
![](/skins/images/D2683F18326913BBA0436CB7114DD569/responsive_peak/images/icon_anonymous_message.png)
Hi everyone
I need help about clear web services memory. I use an web service address(url) that include JSON code this url recorded the somewhere in XDK. I want to clear its. Where is it? and how can I clear this url? I try doing it with "intel.xdk.services.clearData(); " command but it is not work? How can I do it?
(My web services data name is LNLAyatar3Bolge)
