Software Archive
Read-only legacy content
17060 Discussions
IOS Build Error Message: Verify your build assets error message
Declan_M_
I am trying to build an app for IOS (Ionic/Cordova) but I keep getting the following error message: "Verify your build assets are correct and try again". There is no further information to help debug the issue (that I know of?).
After countless builds I have come to the conclusion that I have either too many files or the total file size is too big. Basically I have about 120mb of images in the app and when I reduce the quantity, it builds no problem.
Does anybody have any suggestions on what to do to prevent this?
PaulF_IntelCorp
Android store apps are limited to 50MB in size, so 120MB of images would not make it into the store. The build system has a practical limit on the size of apps it can build, I don't know the precise number, but you have probably exceeded it.
This SO post might help: http://stackoverflow.com/questions/23564012/upload-photo-android-to-blobstore-gae
Declan_M_
Thanks for the heads up on the file size limit! Apparently I can use expansion APKs to load the images into the app through the play store.
Strangely enough the IOS app built on the third attempt, without reducing the file size.
John_H_Intel2
I see that you have a few successful builds. Due to the size of your app, it could have been a network hiccup that caused things to go south...
