Software Archive
Read-only legacy content
Installing EFI shell on bootable usb stick
Shankar_l_
Hi
I am trying to install EFI shell on bootable usb stick using intel's provided tools and following Intel's Bootable EFI disk Instructions guide.
but I am getting Write DBR and MBR failed error. Attached is the complete log.
Any hint?
Gael_H_Intel
Can you tell me what tools or bootable EFI disk instructions you are using?  Also are you working on client or server?
Gael
Shankar_l_
Hi
I am working on client side. I have Dell inspiron M4400 laptop and I want to run some tests in EFI shell that if it is rightly provisioned for TXT.
Attached is the instruction file I am using.
Gael_H_Intel
Shankar - my apologies.  I missed that you posted an update.
I have forwarded your information to the TXT team.  I will let you know when they have taken a look.
Gael
Gael_H_Intel
Hi Shankar,
Here is some information that I have received from the TXT Team.
Also here are instructions from sourceforge on how to make DUET Drive(EFI Bootable) that I have successfully used and are very good. Scroll down to the README.
http://sourceforge.net/p/tianocore/edk2/ci/master/tree/DuetPkg/
Also
Note though that they process has changed slightly, with the release of UDK2015.  It would be best to go to TianoCore.org and get the latest UDK2015 release, then go to the /DuetPKG directory and follow the instructions in the readme.txt file.  (https://sourceforge.net/projects/edk2/files/UDK2015_Releases/UDK2015/UDK2015.Complete.MyWorkSpace.zip/download
