Software Archive
Read-only legacy content
17060 Discussions
Integration of Open Watcom C++ compiler - details, performance evaluation, etc
SergeyKostrov
Valued Contributor II
*** Integration of Open Watcom C++ compiler - details, performance evaluation, etc *** Welcome Back, Open Watcom C++ compiler! At the end of 2015 a decision was made to integrate Open Watcom C++ compiler v1.9 with a project I've been working on since 2009. I used Watcom C++ compiler in the middle of 90th ( last century! ) and I know how superior it is when it comes to optimization of C and C++ codes. Honestly, I was concerned about timing of the integration, that is end of the year, Christmas almost "knocks" to the door ( just two weeks before December 24th ), however a significant portion of the integration was completed in about 6 hours and I managed to compile C/C++ sources and executed some test-cases. Even if the work is still in progress on stabilizing codes and solving some little technical problems I could say that The Legendary Watcom C++ compiler is Not at the top of a list of the Modern optimizing C/C++ compilers. First of all, because version 1.9 is 32-bit only and does Not fully support, or does Not support At All, some Hot-Modern technologies. There is No support of SSE 2.x, SSE 4.x, AVX, AVX2, FMA instructions, OpenMP, Intel intrinsic functions, etc. But, don't be too frustrated because Open Watcom C++ compiler team is working, this is an Open Source Project now, and I hope that a new version of Open Watcom C++ compiler will be released in the future. I will follow up with more technical details and performance evaluation numbers on a set of scientific algorithms later. I will demonstrate how good Open Watcom C++ compiler is compared to Borland, MinGW, Microsoft, Intel and Turbo C++ compilers.
SergeyKostrov
[ To Ahmed S. ] Any questions? Is there anything I need to explain with more details, or to provide more information? Just let me know.
SergeyKostrov
Here is some update... >>... >>...That is why integration of Watcom C++ compiler is Not exception and two small core >>subsystems of the library are improved already... >>... An impact of integration of Watcom C++ compiler is very positive for the project since one subsystem, an Intrinsic Run Time Abstraction Layer ( IRT AL ), was redesigned completely. A Domain-like architecture was indroduced in a new design. However, it took for me more than 3 weeks and it was a little bit unexpected. Some overall details about the Domain-like architecture of the Intrinsic Run Time Abstraction Layer ( IRT-Domains AL ) could be provided.
Bernard
>>>I wanted to say that even if a priority of some STL-based processing ( a function, or a set of functions, etc ) is boosted to Above Normal or Time Critical it can not outperform a processing ( a function, or a set of functions, etc ) implemented in pure C language>>>
This is quite interesting observation.
More than one month ago I posted question about the problem related to using #pragma prefetch on STL std::vector. I observed during the compilation phase ICC issued warning about the incompatibility of that #pragma and simply disabled it. Now by reading your answer I came to conclusion that probably ICC  did not recognize std::vector as a plain dynamically allocated array (template parametrized on T) wrapped in object.
Bernard
@Sergey
What is your opinion on template meta-programming as a mean of compiler type safe attempt to perform some computation at compile time? Judging by my own experience inclusion of  small meta-functions can actually be "computed" at the compile time. Here I mean "metafunctions" for computation of trigo functions (without extensive argument checking).
SergeyKostrov
>>What is your opinion on template meta-programming as a mean of compiler type safe attempt to perform >>some computation at compile time? Judging by my own experience inclusion of small meta-functions can >>actually be "computed" at the compile time. Here I mean "metafunctions" for computation of trigo functions >>(without extensive argument checking). I do not have a well defined opinion about that. It looks interesting but I think it could create some portability problems. You know that I've been doing a Highly Portable programming and I'm always "on guard" when it comes to usage of something that could create lots of problems some time later.
SergeyKostrov
I'd like to provide an update related to a 64-bit version of Watcom C++ compiler v2.0.0. Even if the compiler and linker, and many different helper utilities, are ported to 64-bit platforms generated binary codes are still 32-bit! I hope that Open Watcom C++ compiler team will finally release a true 64-bit version of the compiler.
SergeyKostrov
In order to see if there are any improvements in version 2.0 compared to a previous version 1.9 see that thread: ... https://software.intel.com/en-us/forums/watercooler-catchall/topic/673458
