Software Archive
Read-only legacy content
17061 Discussions
Intel FlexLM serving Intel licences and Autodesk licenses
DRuiz3
Some weeks ago, I configured an Intel FlexLM server for serving Intel Parallel Studio XE and other compilers licenses. Now, I have to serve Autodesk Inventor licenses that also runs with FlexLM server.
Can I use the same server for serving Autodesk licenses? I have read in http://software.intel.com/sites/default/files/article/148795/flex-ug_1.pdf that I can combine two (or more) license files.
Hubert_H_Intel
Yes, you can run the Intel vendor daemon with an existing FLEXlm license server (lmgrd) as long as the license server version is not older than the vendor daemon. Actually our Intel vendor daemon INTEL runs version v11.11.0.0 and so lmgrd needs to be at least on that version.
If that's not the case you can run an Intel license manager separately (also on the same server, but on a different port) to serve the Intel vendor daemon.
Does this help?
Regards, Hubert.
